98 Civic, B20B engine question
Old Sep 6, 2008 | 02:45 PM
mazzucha's Avatar
Default 98 Civic, B20B engine question
Hi guys,
I have a 98 Civic with a CR-V engine , I think is the B20B, because the computer have the " check engine " light on , I took it to my friend and the error is a " incorrect gear radio " in the transmision. The dealer said to replace the solenoids. I did replace them but still the same code. So, I took it to a transmision guy and he said that my 98 Civic has a CR-V engine and a Integra trans. So.. should I replace the computer for a Integra's computer ?.. or put different trans ?.. what you think guys ?
My problems is that I have to pass the emission test !!! that's it !
Old Sep 7, 2008 | 07:56 AM
IanB's Avatar
Default Re: 98 Civic, B20B engine question (mazzucha)
Sounds like you are using a CRV auto ecu, change to an Integra 5M ecu as the B20b is just a bigger bore B18b, make sure you get the right OBDx ecu.
Old Sep 9, 2008 | 03:07 AM
mazzucha's Avatar
Default Re: 98 Civic, B20B engine question (IanB)
The conectors are all the same in honda ?
JRICH5200
Feb 22, 2011 12:18 PM
d15b_civic
Mar 15, 2009 09:33 PM
wishihadaskyline
Acura TL, RL & ZDX
Oct 16, 2002 02:35 PM
