93 EX rear window defrost problem (already searched)
Old Sep 6, 2008 | 11:13 AM
xnvb's Avatar
Default 93 EX rear window defrost problem (already searched)
I just tried searching this problem and seeing if I could figure it out on my own, but no luck. The topics I found don't really cover what's wrong.
So basically, it's getting colder here in Washington as summer ends, and my rear window defrost on my 93 EX coupe doesn't work, so I can't see out the rear window at night. I push the switch on the dash, and I don't get the little orange light showing it being on.
Now this dash and all of the controls were swapped from a 95 Si, so I don't know if that would make any difference in helping to troubleshoot but I figure it's worth mentioning.
Where should I start looking, and what steps should I start taking to find out what the problem is and repair it?
Old Sep 6, 2008 | 07:41 PM
xnvb's Avatar
Default Re: 93 EX rear window defrost problem (xnvb)
No one's had this problem? I know some Honda guru out there knows what's wrong and how I can fix it
Old Sep 6, 2008 | 08:16 PM
Unit44justin's Avatar
have you checked your fuse?? maybe the switch isnt pluged in? Check to see if the switch is bad.
Old Sep 6, 2008 | 10:46 PM
xnvb's Avatar
Default Re: (Unit44justin)
Which fuse is it, and where would I locate it? I'm still super new to the Honda stuff and don't know where I would look. I think I know where the fuse box is, but I'm not 100% sure and don't know which fuse I would check.
Old Sep 7, 2008 | 05:51 AM
ifIexplode's Avatar
https://honda-tech.com/zerothread?id=1966666
hook it
Old Sep 7, 2008 | 10:05 AM
xnvb's Avatar
Default Re: (ifIexplode)
That helps a lot, thanks a ton
Old Sep 8, 2008 | 08:56 PM
xnvb's Avatar
Ok, so I found all of the fuses I needed and went and replaced a bunch of fuses in both compartments on the car, under dash and under hood.
The rear defroster still doesn't work. What would my next step be in troubleshooting to find out what the problem with it is?
Old Sep 9, 2008 | 12:35 AM
xnvb's Avatar
Default Re: (xnvb)
Correction, I fixed it! I just need to fix the switch so the light comes on and off for it.
dewey316
Jan 4, 2014 01:50 PM
Civic082382
Jul 29, 2013 08:16 PM
honda305
Honda Civic (2001 - 2005)
Jul 8, 2011 03:10 PM
