Whats the best way to remove the side modlings?
Old Sep 6, 2008 | 07:19 AM
EvenStar's Avatar
Default Whats the best way to remove the side modlings?
95 accord
Is it safe to just pop it out using a flathead?
Old Sep 6, 2008 | 08:08 AM
waciii's Avatar
Default Re: Whats the best way to remove the side modlings? (EvenStar)
I'm curious to know the answer too but it doesn't seem that easy.
Found this: http://www.honda-acura.net/for...dings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
The side moldings are the tricky ones. You gotta take off the door panel and squeeze the clips holding it on from behind. Squeeze it and push it out. For the molding in the front you gotta get to the clip thats inside the inner fender well lining.
Seems to be consistent that pretty nasty looking Clip #9 in the diagram:
Modified by waciii at 9:31 AM 9/6/2008
Old Sep 6, 2008 | 08:43 AM
Whiteccord's Avatar
Theres going to be holes.
Old Sep 6, 2008 | 10:31 AM
SuShiBoiiii's Avatar
Default Re: (Whiteccord)
take off door panel and the weird bag thing that covers the door internals and then you should see the clips that you push
Old Sep 6, 2008 | 11:18 AM
waciii's Avatar
Default Re: (SuShiBoiiii)
The weird bag thing is vinyl or low-density polyethylene and that really weird stuff that seals it is butyl tape.
Here's a write-up on the whole thing:
http://www.tegger.com/hondafaq/doorseal/index.html
Old Sep 6, 2008 | 11:22 AM
Ross 2.0's Avatar
In a Junkyard near you.
If you just rip them off it WILL leave dents on the door.
alex1321
12
Jan 25, 2013 08:59 PM
91hondacrx
Jun 23, 2006 10:15 PM
Lewy. Dee Ayy
Jan 16, 2006 07:01 PM
SoCar
Nov 18, 2003 01:37 PM
cyberhide
Jul 5, 2001 12:36 AM
