Building B16
Old Sep 5, 2008 | 11:03 PM
kryptonight's Avatar
Default Still waiting for useful info on this topic
Still Waiting For Info On Questions Below
what would my whp be for this set up a estimate with good tuning? What will gas mileage be like? and now that i viewed some videos of similar set ups is there any way i can make the idle a bit more quiet? Also im stuck deciding i can swap out the idea of B16 and go with B18C block and B16 head with the rest being same setup.. God this Sucks and hard to decide..
My B16 build list
B16 Block $99 --- Pick Your Part
GSR Head $40 --- Pick Your Part
ls crankshaft $153 --- New From Kragen AutoParts
will i have to notch the gsr head for these to fit? Or is there a better pick for pistons?
Spoon Sports JDM Type R Pistons $360
Eagle Forged Rods $299 keeping 81mm bore hone only
Tenzo R Valve Cover $159
Skunk2 Valves $276
Skunk2 Titanium Retainers $180.99
Skunk2 Valve Spring Set $196
Skunk2 Pro2+ Cams $548
Skunk2 Cam Gears $191
Skunk2 Intake Manifold $242
Skunk2 Throttle Body $375
Skunk2 Fuel Rail $123
Greddy 4-2-1 Header $369
$3,590
Tranny:
can i place the B20A tranny into this transmission aka the bitch tranny for throwing rods
Anyone know how i can get a lower gear ratio out of other b series motors i know the 1 gen Acura has some smaller 1-4 and i could keep my 5th but i would also like a great final gear any ideas
If there is a cheaper flywheel that is good as this then please post
Toda B-Series Lightweight Flywheel $450
If there is a better cheap lsd kit please post
Spoon LSD Kit $649
ACT Clutch Kit Stage 2 $400
$1,499
Misc:
iL4 Performance Clutch Lines $49.83
MSD Pro-Billet Distributor Kit $250
NGK Power Cables (Spark Plug Wires) $119
$418
with the B16 set up above i should have a 12.16:1 cr and a 1834cc displacement
Modified by kryptonight at 6:16 PM 9/12/2008
Modified by kryptonight at 6:17 PM 9/12/2008
Old Sep 6, 2008 | 02:53 AM
steveteggy92's Avatar
Certainly would make for an interesting setup, I can think of better ways to spend 11k though...
Old Sep 6, 2008 | 06:43 PM
SIred91's Avatar
Rainman
Default Re: (steveteggy92)
900 for a DC header
ROFLMFAO!!!!
Old Sep 6, 2008 | 06:53 PM
jim9's Avatar
Default Re: (SIred91)
I dont get that either.... Is it really worth that much :/
SP GARAGE
Mar 23, 2011 07:42 PM
2SLO
Apr 4, 2008 11:01 PM
bt redliner
Sep 17, 2005 07:48 PM
