Are 04' RSX suspensions interchangable with 06 RSX?
Old Sep 5, 2008 | 09:02 PM
tommyboi116's Avatar
Default Are 04' RSX suspensions interchangable with 06 RSX?
I wanna swap 04 stock suspension into my 06 is that possible? Going back to stock, and the only cheapest way i see
Old Sep 6, 2008 | 02:10 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Are 04' RSX suspensions interchangable with 06 RSX? (tommyboi116)
Only if you put on the entire shock/spring/tophat combo. You can't mix and match.
Old Sep 7, 2008 | 09:01 AM
DC5_lov3r's Avatar
Default Re: Are 04' RSX suspensions interchangable with 06 RSX? (Todd00)
Are the drop and handling the same or different from an 02-04?
Old Sep 7, 2008 | 05:11 PM
DC5Berry's Avatar
^^ Not totally sure about that, but one reason they are different is that the springs are different (wound the opposite way)...or something like that
Old Sep 7, 2008 | 07:00 PM
FerreiraCompetitions's Avatar
Yes its fits fine. I have stock type-s suspenders for sale here in Boston BTW.
Old Sep 8, 2008 | 08:07 PM
Will the type s fit into the base 06'. let know I'm interested, email me at ho.loc16@yahoo.com. we can meet up
Old Sep 9, 2008 | 05:28 AM
atsed24's Avatar
NO NOT ALL THE PARTS THERE WAS A REVISION FOR 05-06 DO SOME RESEARCH
Old Sep 9, 2008 | 10:05 AM
Todd00's Avatar
Default Re: Are 04' RSX suspensions interchangable with 06 RSX? (atsed24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atsed24 &raquo;</TD></TR><TR><TD CLASS="quote">NO NOT ALL THE PARTS THERE WAS A REVISION FOR 05-06 DO SOME RESEARCH</TD></TR></TABLE>
As I already said, you can't mix and match parts. Only the entire assembly can be swapped over.
Old Sep 9, 2008 | 03:05 PM
crapanese's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
As I already said, you can't mix and match parts. Only the entire assembly can be swapped over.</TD></TR></TABLE>
if you have to swap the whole assembly and it works fine, then why are full coilover setups "supposedly" different from 02-04 as opposed to 05+ ??
G2_Fella
36
Feb 21, 2005 07:08 PM
Stumpy
Oct 29, 2004 05:49 PM
player2z
Oct 31, 2003 06:35 PM
