OK SO... My car won't start!!! urgent problem
Old Sep 5, 2008 | 08:54 PM
naler62188's Avatar
Default OK SO... My car won't start!!! urgent problem
Ok so my battery is good, my starter is good.
but my car doesn't start. when i turn the key to acc or on everything is normal, then when i turn it to start... nothing. then it goes back to on position and it's all normal.
does anyone know what the problem could be???
Old Sep 5, 2008 | 08:59 PM
Kendall's Avatar
When you say the starter is good, do you mean the engine is turning over normally and nothing from there, or is there literally nothing happening.
Old Sep 5, 2008 | 09:05 PM
Jimmy's Avatar
Global Moderator
Do you hear the fuel pump priming?
Old Sep 5, 2008 | 09:08 PM
naler62188's Avatar
Default Re: (Jimmy)
no i mean NOTHING happens,
and yes i do believe the fuel pump is all good.
Old Sep 5, 2008 | 09:12 PM
CompanyFlow's Avatar
Default Re: (naler62188)
So then how do you know the starter is good?
Old Sep 5, 2008 | 09:28 PM
naler62188's Avatar
Default Re: (CompanyFlow)
it's brand new and they tested it
Old Sep 5, 2008 | 09:52 PM
MrViet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naler62188 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so my battery is good, my starter is good.
does anyone know what the problem could be???</TD></TR></TABLE>
what do you mean nothing? when you just turn it on does it make a click sound? or multiple clickin? does it sound like its going on like you know that *eeeh *eeh *eeh sound like its not getting enough gas?
lets get real specific.
Old Sep 6, 2008 | 12:05 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: (MrViet)
before u go into relay.check the battery ground wire make sure they r tight and are good conducter.
Old Sep 6, 2008 | 12:14 AM
Default Re: (KILLAB17VTEC)
He gets power.
Old Sep 6, 2008 | 05:01 AM
naler62188's Avatar
when i say nothing i mean nothing, at all. well from the driver seat. under the hood you can hear the fuel pump but just one click, that's it. oh and my negative terminal sucks, so i'll change that out.
Old Sep 6, 2008 | 07:54 AM
nonsense's Avatar
check the clutch switch. It may "think" you're not pressing in the clutch.
Old Sep 6, 2008 | 11:53 AM
BoSox46GSr's Avatar
Default Re: (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naler62188 &raquo;</TD></TR><TR><TD CLASS="quote">when i say nothing i mean nothing, at all. well from the driver seat. under the hood you can hear the fuel pump but just one click, that's it. oh and my negative terminal sucks, so i'll change that out.</TD></TR></TABLE>
Hmmm.... I din't know they put fuel pumps under the hood now... That's not the fuel pump you hear, it will make a buzzing sound coming from the back seat, the main relay clicks, but it should be a few times. You need to know if you're getting fuel, and/or spark. Then it will be easier to pinpoint your problem, thus being easier to fix without spending loads of money on parts you don't need.
Old Sep 6, 2008 | 01:16 PM
S1NFUL RL1 619's Avatar
Default Re: (BoSox46GSr)
is there gas in the tank??
Old Sep 6, 2008 | 03:15 PM
MrViet's Avatar
it could just be your battery if its just a click you hear. does your radio work ? head lights? electrical equipment?
try getting a jump start from another car.
because i remember when my car would just make a simple click sound. headlights turn on, stereo works but in order to turn it on i needed a jump. that narrowed down my problems.
Old Sep 6, 2008 | 07:39 PM
naler62188's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrViet &raquo;</TD></TR><TR><TD CLASS="quote">it could just be your battery if its just a click you hear. does your radio work ? head lights? electrical equipment?
because i remember when my car would just make a simple click sound. headlights turn on, stereo works but in order to turn it on i needed a jump. that narrowed down my problems.</TD></TR></TABLE>
no that isn't it, it won't start like that. it does, however, roll start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S1NFUL RL1 619 &raquo;</TD></TR><TR><TD CLASS="quote">is there gas in the tank??</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmm.... I din't know they put fuel pumps under the hood now... That's not the fuel pump you hear, it will make a buzzing sound coming from the back seat, the main relay clicks, but it should be a few times. You need to know if you're getting fuel, and/or spark. Then it will be easier to pinpoint your problem, thus being easier to fix without spending loads of money on parts you don't need.</TD></TR></TABLE>
you didn't know that, damn. you need to do some reading, lol jk jk
no i mean i hear a click under the hood and the fuel pump does click(and yes from the back seat, which isn't there)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">check the clutch switch. It may "think" you're not pressing in the clutch. </TD></TR></TABLE>
um i don't think that is it either i disconnected the wires and ran one wire to connect them and still nothing
I'm going to my friends house tomorrow to hopefully solve this damned problem but i do need all the help i can get. I am pretty much a n00b, I'v only had this car a little over a month.
Old Sep 6, 2008 | 10:49 PM
Do you have a kill switch?
Old Sep 6, 2008 | 11:10 PM
khmers0uljah's Avatar
From: I'm always painting & polishing shiet, California
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a kill switch?</TD></TR></TABLE>
I ran into this problem a couple of days ago. I didn't know what the switch was for and I accidently hit it and my car wouldn't start.
Old Sep 6, 2008 | 11:40 PM
Default Re: (khmers0uljah)
I actually had a switch that would overheat and short in and out every now and then. I had to mcgyver it on the side of the road one day with a pepsi can tab and my keys.
Old Sep 7, 2008 | 09:35 AM
naler62188's Avatar
a kill switch?
Old Sep 7, 2008 | 06:34 PM
A switch inside the car that disables either the fuel pump from working or cutting power to the car. You should check your fuses and relays btw.
Old Sep 8, 2008 | 07:44 AM
naler62188's Avatar
ok, so problem solved, and it only took ten bucks and about fifteen minutes to fix. So my starter wasn't getting power. All i did was run a little 16 gauge wire to the battery(it's in the trunk), and ran it through my car to the starter, and about halfway down the wire i cut it and got me a push button star thing, it still isn't mounted but the damn thing works
Old Sep 8, 2008 | 09:46 AM
It works, but you didn't solve the problem.
Old Sep 8, 2008 | 08:27 PM
naler62188's Avatar
How so?
Old Sep 8, 2008 | 09:46 PM
MrViet's Avatar
you shouldn't need a 16 gauge wire thingy to even start the car in the first place. that means something that was supposed to work normally didn't work.
Old Sep 9, 2008 | 05:39 AM
naler62188's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">It works, but you didn't solve the problem.</TD></TR></TABLE>
Huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrViet &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't need a 16 gauge wire thingy to even start the car in the first place. that means something that was supposed to work normally didn't work.</TD></TR></TABLE>
Ok, you totally lost me. It was actually a 14 gauge wire, btw. even though i know what I said earlier. Obviously something that was supposed to work didn't work, I had wiring issues. So instead of spending alot of time trying to figure out where the problem is i found a, imo, better solution. And pretty soon I'm getting an S2K push button and when I do that I'm going to mount it right and make it look good and whatever.
