not so good gas mileage
Old Sep 5, 2008 | 05:40 PM
19integra94's Avatar
Default not so good gas mileage
Ok so I got a 94 integra with 202,000 miles, prettty much the only thing I have done is a intake,header,exhaust. The intake and header are off brand and I still have the stock exhaust I just have a different muffler on it. Most all of this I got done last december and Ive never had a problem with the car, but just recently I realized my gas mileage has started to drop little by little. Im not really really sure whats the problem I almost want to say its the larger header going to the stock exhaust and its not lettin enough exhaust get out. but Im not really sure.
Old Sep 5, 2008 | 05:42 PM
mtber's Avatar
Default Re: not so good gas mileage (19integra94)
What mpg are you averaging ?
Is your check engine light on ?
Old Sep 5, 2008 | 05:44 PM
Default Re: not so good gas mileage (mtber)
not sure im like barely passing 200miles on a full tank tho and my check engine light came on tonight thats why I posted this but Im do for a oil change which is why I think it came on.
Old Sep 5, 2008 | 08:14 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19integra94 &raquo;</TD></TR><TR><TD CLASS="quote">not sure im like barely passing 200miles on a full tank tho and my check engine light came on tonight thats why I posted this but Im do for a oil change which is why I think it came on.</TD></TR></TABLE>
Pull the code and see what's kicking the light..
Needing an oil change isn't going to throw a code.. however the maint required light will come on.. which can easily be reset..
As far as the horrible gas mileage.. I'd start with
- Running some fuel injector cleaner or seafoam
- Pull your O2 sensor and check the condition of it.. this could likely be the cause..
- Replace fuel filter..
Pretty much do all routine maintenance and see if that helps with the MPG.
Old Sep 5, 2008 | 08:24 PM
rufridn's Avatar
I had I/H/E. By removing only my exhaust and intake, i went from getting 260/tank to 320/tank. I was amazed by how much of a difference it made. Both comparisons were made with the same driving habits.
Old Sep 5, 2008 | 09:18 PM
GsrPatrick's Avatar
Default Re: (rufridn)
i have a 1998 Gsr integra 4 door, and it has I,H.E and im getting around 25-29 mpg..
im not sure what im spose too get but thats pretty good in my book
Old Sep 5, 2008 | 09:54 PM
MrViet's Avatar
Default Re: (GsrPatrick)
25 - 30 is good.
theblkrascal
Honda Civic (2001 - 2005)
18
Sep 28, 2006 12:20 PM
zeroyux
Sep 16, 2006 02:05 PM
log1c
Jul 12, 2005 03:32 PM
FunkDaddyFresh
Oct 2, 2004 09:09 AM
Todd00
25
Jun 9, 2004 03:50 PM
