Transmission & Drivetrain Gearboxes, Differentials, Clutches
Gen 5 CX/VX into Gen 6 car?
Old Sep 5, 2008 | 04:46 PM
brucepick's Avatar
Default Gen 5 CX/VX into Gen 6 car?
[EDIT]
Are there computer / OBDII issues when you swap a '92-95 5-speed into a '96-'00 car??
[/EDIT]
Still a nooob.
Will be shopping for a Civic, likely a Gen 6.
Definitely a 5-speed standard.
I want to swap in taller gearing.
Will a CX/VX tranny from '92-'95 be OK in a Gen 6 car?
Will it be OK in an EX if I get one, with its 127 hp?
I mean, that won't be too much hp for the little old tranny, will it?
(Dunno yet which version of Civic I'll be getting.)
Background - - -
This is mainly a fuel economy thing.
I drive 52 mi each way to work.
The plan is to get a CX/VX tranny and swap it into whatever Gen 6 car I end up with.
The gearing will be taller than the Gen 6 for an mpg improvement.
I don't need blazing performance, just blazing mpg.
My current ride is 3050 lb. and 115 hp, auto trans.
So any stick Civic will outperform my Volvo "brick" even with a taller gear tranny swapped in.
Thanks!
Modified by brucepick at 2:36 PM 9/7/2008
Modified by brucepick at 2:56 PM 9/7/2008
Old Sep 5, 2008 | 05:18 PM
Bense's Avatar
why not just get an HX? it's only 14.5% shorter.
the vx has smaller wheel diameter, i doubt youll be able to acheive more mpg in an hx by using a vx 3.25 final
Old Sep 5, 2008 | 06:11 PM
brucepick's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">why not just get an HX? it's only 14.5% shorter.</TD></TR></TABLE>
HX is pretty tough to find. It's way easier to find an EX or even DX. And plenty of HX's have been tuned/hacked into 'performance' cars instead of the mpg champs they were designed to be. So, if a nice and reasonably priced HX doesn't appear when I'm shopping I might very well be able to get some other couple Civic + tranny swap for my money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote"> the vx has smaller wheel diameter, i doubt youll be able to acheive more mpg in an hx by using a vx 3.25 final</TD></TR></TABLE>
Yes VX car has a smaller diam wheel but the VX tranny has taller gearing than what's in the Gen 6 cars. So the net result if I put one in a Gen 6 car is approx 20% taller gearing than I would have had with a stock Gen 6. Just about right for a nice mpg gain without killing off the engine's ability to move the car.
Old Sep 5, 2008 | 06:27 PM
Bense's Avatar
don't fall into the misconception that no matter what lower rpm = more mpgs.
the vx trans is garbage, not only is the final drive tall, but the gears are just too far apart. It would be much better if you used the dx 1-5 gearing with the vx 3.25 final drive (that is if you're hellbent on that low of cruising rpm)
all 96-00 5th gears are 0.702, which is the same as the 92-95 dx/vx/cx/lx.
96-00 hx trans is a dx trans with a 3.722 final drive instead of a 4.058
Old Sep 5, 2008 | 07:09 PM
Aquafina's Avatar
Best mileage I've gotten with any of my trans setups (stock Y7 HB, Y7/Y8 4.714 FD,) is with the Y8 trans with MFactory 1.000 5th gear (4.250 FD).
Old Sep 5, 2008 | 08:08 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Aquafina)
53 mpg with a 5g DX tranny.
3.722 FD tranny with .771 or .750 5th is good also.
OK, two paragraphs just disappeared, not retyping, it was mainly aimed at WP-D
Old Sep 5, 2008 | 08:09 PM
Bense's Avatar
lol hey guys
Old Sep 5, 2008 | 08:32 PM
Mista Bone's Avatar
D Tranny Guru
Swamped with school again Bense?
OH yeah, I'm getting a "second chance" with a certain team.
Seems my name popped up on the "Bobby" radar again........
Old Sep 7, 2008 | 02:48 PM
brucepick's Avatar
Default Re: (Mista Bone)
bump
Old Sep 8, 2008 | 07:48 AM
Relic1's Avatar
the largest issue I see with this will be the ECU, the trans gearing is programmed into the ECU. When the trans is changed it can seriously change the way the car runs. You may end up with less mpg than with the stock trans.
The best part about the HX... it will give you everything you want in one package, no work required.
For that Honda quality I'd search high and low for a HX and be patient.
For what it's worth, I know exactly how you feel, I've been searching for a VX in good shape for a while also.
Old Sep 8, 2008 | 04:24 PM
brucepick's Avatar
Default Re: (Relic1)
Thanks Relic1.
Sorry to learn the bad news - tranny swap isn't a good way to get better mpg due to the change snarfing up the ECU. Don't wanna do that!
Yeah, maybe I'll just be real patient and watch for an HX.
Or maybe I'll buy the first nice condition Gen 6 couple that I can find.
We'll see how it goes.
Old Sep 8, 2008 | 07:49 PM
Relic1's Avatar
there are other ways to achieve your goal.
Converting the car to OBD1, tuning the ECU with a wideband and setting the right trans settings is always an option. Most of the leading tuning programs out there allow for a wideband input during closed loop operation.
You'd end up with a sort of psudo lean-burn like the VX/HX has, but the power that the stronger engine can deliver.
All though this setup is not for a beginner.
Old Sep 9, 2008 | 03:41 AM
brucepick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">...I know... I can't spell. (and I have dyslexic fingers) </TD></TR></TABLE>
Did'ja hear the one about the dyslexic agnostic insomniac?
Stayed up all night trying to figure out if there really is a Dog.
Ba-da-bum.
(Sorry, I just had to)
Old Sep 9, 2008 | 07:11 AM
Relic1's Avatar
Default Re: (brucepick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brucepick &raquo;</TD></TR><TR><TD CLASS="quote">
Ba-da-bum.
(Sorry, I just had to)</TD></TR></TABLE>
*groan*
tpot90
Feb 24, 2008 07:35 PM
brucepick
13
Jan 24, 2008 07:29 PM
lahight
Apr 21, 2003 02:17 PM
DsITR
Nov 4, 2002 10:45 AM
