Swapped It!
Old Sep 5, 2008 | 02:35 PM
19civicex91's Avatar
Default Swapped It!
Ok so I recently swapped my old d16A6 to my new d16a6. After I have done the swap I have no spark, tested my coil at autozone and shows as fine, checked wiring and grounds. Curious if the resistor box has anything to do with it, any input please
Old Sep 5, 2008 | 03:23 PM
BILLETGRIP's Avatar
Default Re: Swapped It! (19civicex91)
the resistor box has nothing to do with spark. did you check the ground going to the thermostat housing?
Old Sep 5, 2008 | 03:27 PM
Default Re: Swapped It! (BILLETGRIP)
No I will check my grounds tonight, I just need to know where most are and to what, you think it could be the ground on the intake manifold chamber ? I will check on the thermo housing one
Old Sep 5, 2008 | 03:46 PM
BILLETGRIP's Avatar
more than likely you forgot the one on the thermostat housing. thats the most commonly forgotten one and the only one i know of that wouldnt let it start other than the battery of course. the ground is coming out of your wire harness near the housing...it will be obvious when you see it.
Old Sep 5, 2008 | 04:01 PM
Ok thanks I shall check them later then
Old Sep 5, 2008 | 06:46 PM
acmoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">more than likely you forgot the one on the thermostat housing. thats the most commonly forgotten one and the only one i know of that wouldnt let it start other than the battery of course. the ground is coming out of your wire harness near the housing...it will be obvious when you see it.</TD></TR></TABLE>
can smeone post as pic of where that ground comes from, or eloborate more.
Thanks
apekd
Jan 15, 2009 04:57 PM
underpressure02
Apr 30, 2008 04:07 AM
Beau Gotti
Mar 8, 2006 03:15 PM
BuLLDoGG
13
Aug 24, 2005 08:41 PM
ferio 95
Aug 22, 2004 12:53 PM
