EK brake master cylinder upgrade (searched)
Did some searching and got some good and bad info..
Or just more confused
Car 98 Honda Civic HB CX stock
Parts that I have
-ek9 prop valve
-94 integra rear disc brakes
-99-2000 Civic knuckles brakes etc Si USA SiR Canada
I want to upgrade the master cylinder stock is 13/16
I was told the 98 integra RS has a 15/16 and will bolt right up..
Not sure if booster is the same.
But the CTR EK9 comes with a 1 inch master..
Which is the same as a 98-2001 ITR or GSR has the same master cylinder numbers and booster numbers..
Going by this post the GSR, ITR booster is alot larger then the stock booster..
https://honda-tech.com/zerothread?id=818263
https://honda-tech.com/zerothread/1998336
thanks guys
Parts that I have
-ek9 prop valve
thanks guys
joprez
May 7, 2013 02:54 PM
SilverDc2
14
Jul 25, 2005 10:22 AM
sleepyhamsterlx
53
Jan 28, 2005 09:30 PM
