lean afr on start up runing S300
Old Sep 5, 2008 | 09:13 AM
EJ1B18c's Avatar
Default lean afr on start up runing S300
When the engine is started up and warming up in idles fine but my aem uego afr wideband is reading 17.1 and even going off chart. when driving the afr is fine. just idle. im using S300 so can some1 explain how to alter the fuelling or ignition.
running in open loop
skunk2 pro2,s
13:1 CR
i have it idleing at 1050 rpm.Thanks in advance
Old Sep 5, 2008 | 09:34 AM
Relic1's Avatar
could be the wideband warming up, could be the adjustments are off a little in the ECU.
during warm up - water temperature compensation (Fuel Compensation tab)
start up - Post Start Fuel Adjustment (fuel trim tab)
Old Sep 5, 2008 | 10:38 AM
EJ1B18c's Avatar
Default Re: (Relic1)
will do when i get home. thanks
ok im having trouble actually getting the fuel compensation table as i file. how do i do this
Modified by EJ1B18c at 9:22 AM 9/8/2008
excaliburcombo
Engine Management and Tuning
Jun 2, 2015 04:48 PM
mafia
Feb 11, 2014 03:15 PM
SPOOLINmatt
Feb 9, 2011 04:49 AM
em1 Ziggy
Apr 20, 2006 03:43 PM
deacs
Oct 14, 2002 12:57 PM
