Need some help Please...
Ok recently my problem is from this thread
https://honda-tech.com/zeropost...80667
Ok I recently got this car as a trade. It already had the GSR engine in it. To make things clear I know nothing about B series engines since this is my first. So im trying to make sure everything adds up. Ok.... I just bought a multimeter(of which I don't know how to use) to try to test my vss. As stated my old thread I stated I have a Cel for VSS. Replaced and still same problem. So I bought a multimeter to see if I can find what's going on. So please if anyone out there can help me. Also I noticed that I have 2 wires coming from the engine bay to the ecu. The guy I got the car said he wired up the secondary butterfly. I've been searching up and down to learn about my engine but I need some help cuz I need to register it and smog the damm car. And a CEL=FAIL. Plus I now don't have Vtec. Also my ecu reads:
37820-P72-A02-970-105029
Iis this ecu the right one. Cuz I searched the faqs and ecu's list and so far that number complies to a OBD1? Unless that thread is missing something. Please read thru the above thread for more details of my concerns.
Ok well I tested the VSS plug and im getting in one wire 4.9v and on the other 11.8-11.9v. So im guessing im ok. So what's next? A faulty sensor? How can I check my speedometer? Or my ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReactioN »</TD></TR><TR><TD CLASS="quote">did you reset your ecu after switching VSS? and the p72 is the right ecu for that motor.</TD></TR></TABLE>
Yup....I removed the ecu fuse under the hood. But even so my speedometer still doesn't read. So even if I did or didn't remove it my speedometer still doesn't work at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReactioN »</TD></TR><TR><TD CLASS="quote">then i have no idea..have you checked your ECU to make sure nothing was burnt?</TD></TR></TABLE>
No......never thought about that. If I open it up what am I looking for? Anything in particular?
steveo907
Mar 31, 2010 07:17 PM
BLITZ
Apr 18, 2002 08:23 AM
