Wiring/Connection from JDM Head Lights to OEM Wiring
From: Autobahnland, A96/A99/A92/A9/A4 - 255 kph ITR speed, and itīs legal!
Hello Guys.
Iīve got a problem with my wiring. I found the picture on HT that shows me the colours from the head lights (4 colors). But.... i realy donīt know.
I want it that way:
Engine on: no lights
Step 1: front city lights, tail lights, cluster & mid console light, clock dimmed
Step 2: front city lights, low beam, tail lights, cluster & mid console light, clock dimmed
Step 2 + pull: high beams, front city lights, low beam, tail lights, cluster & mid console light, clock dimmed
But actually it works like this:
Step 1: nothing happend
Step 2: front low beams are on, all the others are off
Step 2 + pull: low beams are still working like before, all the other lights (high beams, cluster light, mid console light, tail lights + rear side marker lights, license plate light, clock) just work for a second and the they get all very low light. Very hard to see, even at night.
I realy donīt know what to do. Is it a grounding problem, because of the flashing first and the the very low light...
I guess the wiring colors from the Acura DC2R (USDM) and my Honda DC2R (EUDM) are the same. The head lamps are from a 97 JDM DC2 (non HID).
So can anybody tell me which colors must be connected together? Maybe pls a foto/picture from the wiring?
And my other question:
The yellow JDM fog lights are not connected yet. But i have the fog light **** already there, but without wiring. Is there are wire already, or do i have to install one first before i can switch the fog lights off and one via the button!?
Thank you very much!!!
I want it that way:
no one?
or is it wrong here? if yes, could an admin copy it to the right (Integra)?
thanks, i will order it then.
but does anyone know which wire color musst stick together to get the 100% perfekt function?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6b18b »</TD></TR><TR><TD CLASS="quote">passjdm makes a plug play harness.</TD></TR></TABLE>
x2
http://passwordjdm.com/Passwor....aspx
x2
ohitstutu
Dec 19, 2005 08:13 PM
