quick harness question...
the car is an 88 civic hf hatch...
we were doing an ls swap and he had a 90 crx si harness laying around. we swapped in the engine and dash harness along with the motor. my question is does the body harness of an 88hf match up with a dash harness of a 90 si? Im guessing no since there is one last set of plugs that dont fit together under dash on drivers side and we arent getting any fuel...I believe this plug deals with the fuel pump because the wires match at the fuel pump and the plug.
If anyone has any experiance with this issue let me konw asap! thanks
lol no you dont...what you talkin about??? engine harness is just fine, i just need to know if the body harness needs to be changed...? 90 crx si engine and dash harness to the 88hf body harness...this doesnt work right?
I believe the Hf chassis came with dpfi correct. You either need to reuse the hf engine harness and rewire it for mpfi, or use a mpfi Si body harness.
Jdmsolutions
May 2, 2009 09:08 AM
