AEM UEGO stuck at 14.7/14.8
Ok so i have been using this AEM UEGO for maybe 2 months now and after moving into college it is stuck reading either 14.7 or .8. I know it used to stay at 14.8 when a wire was out so i checked to make sure it was still all plugged in and it was. the car feels like it is driving absolutely fine. So i'm guessing it's a wiring issue. Does anyone know what i should take a look at? Is it a faulty unit? i'm kind of pissed because afr gauges are not cheap.
well i googled it and some ppl say when it's inbetween 14.7/.8 it could be a wiring problem. i guess i should check that out before i got wasting money on a new wideband sensor
leaded fuel DESTROYS oxygen sensors. If possible, use unleaded high octane at all times!
Oh, and some AEMs tend to eat sensors for lunch. I've never had sensor issues in the 3 innovate widebands I've owned.
i'm using 93 unleaded. does anyone know what sensors can be matched with the aem uego? I heard they were calibrated specifically for the uego. This sucks...i used this thing for two months and now it's fried. i'm still goign to check the pins and hopefully that is my problem.
The sensor AEM uses is a Bosch LSU4.2 UEGO sensor. A over the counter part you can pick up at pretty much any dealership or parts store. However the replacement cost at a dealership or parts store might be through the roof. You should however be able to pick up a replacement sensor from an AEM dealer for $69.63.
The other thing is installation. Make sure you install the sensor correctly have used my AEM UEGO for over 2 years now on the same sensor with race gas. Just follow the instructions on how the sensor should be mounted for positioning which I find most people dont even look at it.
Modified by Rtype16 at 10:20 AM 9/5/2008
i was pretty sure i angled mine in the way it should be...it says like a 10-15 degree angle or w/e in the manual and that's what i did. Maybe i angled it at closer to a 45 degree, but i'm having my downpipe redone regardless so if that is the case i'll make sure they weld it in properly. I measured the pipe and i'm pretty sure i am running past 36" from the turbo also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 »</TD></TR><TR><TD CLASS="quote">The sensor AEM uses is a Bosch LSU4.2 UEGO sensor. A over the counter part you can pick up at pretty much any dealership or parts store. However the replacement cost at a dealership or parts store might be through the roof. You should however be able to pick up a replacement sensor from an AEM dealer for $69.63.
Modified by Rtype16 at 10:20 AM 9/5/2008</TD></TR></TABLE>
You can't pick one up at the part store. it has a built in resistor for the aem unit.
RACEPAK
Engine Management and Tuning
Jul 15, 2011 10:55 AM
