EK9 Civic Type-R VS. Stock DX
Old Sep 4, 2008 | 04:28 PM
SOHC_civic_si's Avatar
Default EK9 Civic Type-R VS. Stock DX
Is there any way of telling if these are REAL EK9 CTR springs and shocks: http://img.photobucket.com/alb...3.jpg I'm going to but them but just want to be sure. Also, is there a difference between the CTR's and the stock DX set? Is the CTR higher grade/quality?
Old Sep 4, 2008 | 04:55 PM
Default Re: EK9 Civic Type-R VS. Stock DX (SOHC_civic_si)
bump/
Old Sep 4, 2008 | 05:37 PM
alphalanos's Avatar
CTR are stiffer. A little more sporty. Honestly you would be better off going aftermarket like Koni.
Old Sep 4, 2008 | 06:31 PM
Default Re: EK9 Civic Type-R VS. Stock DX (alphalanos)
Ok. I can't afford aftermarket suspension and my current shocks are done. Is it still livable for normal everyday driving on bumpy edmonton construction?
Old Sep 4, 2008 | 07:19 PM
bump
Old Sep 4, 2008 | 07:27 PM
.Grimace's Avatar
footwork mastery
how much does he want for them?
Old Sep 5, 2008 | 06:08 PM
Default Re: EK9 Civic Type-R VS. Stock DX (.Grimace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">how much does he want for them?</TD></TR></TABLE>
100 plus shipping, so like 150ish
Old Sep 5, 2008 | 06:20 PM
DC5_lov3r's Avatar
Aren't the part numbers different? from EK9 than a EJ6?
Old Sep 5, 2008 | 08:52 PM
iluvmy2000civicex's Avatar
Default Re: EK9 Civic Type-R VS. Stock DX (DC5_lov3r)
Add another $100 to that and you could get some Skunk2's
Old Sep 6, 2008 | 11:10 AM
Default Re: EK9 Civic Type-R VS. Stock DX (iluvmy2000civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmy2000civicex &raquo;</TD></TR><TR><TD CLASS="quote">Add another $100 to that and you could get some Skunk2's </TD></TR></TABLE>
Yeah only skunk2 springs. I need the shocks and springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5_lov3r &raquo;</TD></TR><TR><TD CLASS="quote">Aren't the part numbers different? from EK9 than a EJ6?</TD></TR></TABLE>
Are they? So your saying that they wouldnt work on my car?
Old Sep 6, 2008 | 11:53 AM
LastGenEK's Avatar
You can buy sk2 shocks about 200 dollars
Old Sep 7, 2008 | 10:30 AM
Default Re: EK9 Civic Type-R VS. Stock DX (LastGenEK)
where? but that doesnt include the springs
Old Sep 7, 2008 | 10:37 AM
.Grimace's Avatar
footwork mastery
DO NOT BUY skunk2 shocks. unless you get the skunk2 pro c coilovers they suck. i've had the skunk2 pro s series coilovers and i wish i never bought them.
Old Sep 7, 2008 | 06:55 PM
Really? are they stiff?
Old Sep 7, 2008 | 08:55 PM
dim-sum's Avatar
CTR coilovers are slightly stiffer but for a tiny bit more extra $$$ try to get actual adjustable coilovers, remember spend the money, spend it once.
Old Sep 7, 2008 | 09:33 PM
Daammnn's Avatar
id just save your money if you want good suspension ive had alot of different kinds now i got tein HA's love em.
Old Sep 7, 2008 | 10:18 PM
92'si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">Ok. I can't afford aftermarket suspension and my current shocks are done. Is it still livable for normal everyday driving on bumpy edmonton construction? </TD></TR></TABLE>
whats your budget?
Old Sep 7, 2008 | 11:34 PM
.Grimace's Avatar
footwork mastery
no WAY too soft
Old Sep 8, 2008 | 06:40 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Probably...the CTR has stiffer springs and different damping. So obviously, the part numbers are different. They're different parts. That doesn't mean they won't bolt onto other 96-00 civics, though.
Example: The D16Z6 and D16Y8 transmissions have different part #s. But they are 100% interchangeable.
Maybe what you were trying to tell him is that you can tell if they're CTR parts if the numbers match up to a CTR. But I think that the OP took it as you were telling him that they are not interchangeable.
What year is your civic, OP?
The car will ride noticeably rougher than the stock DX. They're OEM springs...but the roads in Japan are a lot nicer than the roads in North America...especially Canada. You have bigfoot and big trucks and snow and salt making craters.
Think about the ride you get with a stock ITR...it should be similar. I wanted a set of CTR springs/shocks for my EM1. I don't like rough rides either.
It should ride fine. It's going to be softer than most aftermarket setups anyway.
Old Sep 8, 2008 | 06:42 AM
B serious's Avatar
Default Re: EK9 Civic Type-R VS. Stock DX (dim-sum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dim-sum &raquo;</TD></TR><TR><TD CLASS="quote">CTR coilovers are slightly stiffer but for a tiny bit more extra $$$ try to get actual adjustable coilovers, remember spend the money, spend it once.</TD></TR></TABLE>
Stock CTR **** = quality.
Cheap coilovers = garbage.
Old Sep 8, 2008 | 07:43 AM
bmoua's Avatar
Default Re: EK9 Civic Type-R VS. Stock DX (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
well said...
Old Sep 9, 2008 | 09:31 PM
Default Re: EK9 Civic Type-R VS. Stock DX (bmoua)
It should ride fine. It's going to be softer than most aftermarket setups anyway.</TD></TR></TABLE>
My Civics a 99. Yeah it's more so the insane construction projects that leave the roads probably more horrible than you Americans have ever had to deal with
With that being said I want soft suspension because as I said earlier there is very few roads where I can hug a corner without hitting a huge raised patch of tar filling a crack about 6" deep so I am not too concerned about sporty. I will have to choose between the CTR's or the stock DX. Thanks guys!
pcmoney01
Dec 22, 2010 10:25 AM
bmoua
Sep 7, 2008 05:17 PM
hondacivichatch
Nov 7, 2005 09:31 AM
awdriscol4
Aug 18, 2005 10:14 AM
DR3AM
Nov 2, 2002 04:08 PM
