what mounts for gsr in hatch
hey so i had a b16 swap in my 91 hatch si and then i just put a gsr block with b16 head with b16 cable tranny. the motor sits tilted to the right. what mounts do you use other than the aftermarket mounts. im using precision mounts
well you didn't answer my question. if you look at hasport's site they say that for a b18c you need to do some modifiying to make it work. and if you read it i said i know what aftermarket mounts to use because i have them and ran a b16 in my car before. im asking about the oem tranny mount that is on the top and the chasis mounts to that via an aftermarket mount. also there is the t bracket on the rear,(what car do i take the t bracket from) and the drivers side mount that bolts to the block and has like 2 bolts going up and that is where the aftermarket mount mounts to. i hope you understand now/ so what oem mounts do i use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie »</TD></TR><TR><TD CLASS="quote">well you didn't answer my question. if you look at hasport's site they say that for a b18c you need to do some modifiying to make it work. and if you read it i said i know what aftermarket mounts to use because i have them and ran a b16 in my car before. im asking about the oem tranny mount that is on the top and the chasis mounts to that via an aftermarket mount. also there is the t bracket on the rear,(what car do i take the t bracket from) and the drivers side mount that bolts to the block and has like 2 bolts going up and that is where the aftermarket mount mounts to. i hope you understand now/ so what oem mounts do i use</TD></TR></TABLE>
You should have stated that in the original post. Excuse me for trying to help.
FWIW, I used a B16A drivers side engine bracket and a 90-93 Integra rear tranny bracket in my car, which has a GS-R motor with a S1 cable tranny.
Modified by Redline130 at 2:55 PM 9/5/2008
