DOHC ZC with si dizzy. wiring help. will post pics
ok so i put a 90 si sohc dizzy on my D16a1 because my a1 dizzy went bad and there like 300$ new. i made my si dizzy fit and timed. and i did the mpfi swap so i had to run 2 wires to the sensor on the exhaust cam but now my car is reading limp mode so would it be ok if i ran them 2 wires to the dizzy? would my car run the same? please help.
pics later
pics later
i understand this. buti put a dx dizzy and its in limp mode. how would i hook up the scensor to that? when i usse the si dizzy would i have to hook up the external scensor or could i use the internal one on the si dizzy?
ok. there is no way to not use it? i have 2 of them so i can. can they go bad?
and what else can put my car in limp mode? help
once the wiring is done correct it should come outta limp mode
are ya throwing any codes? or did it run long enough to get codes
i dont think there is a way around not using it
oh it runs just fine i drive it everyday to school and back. it just dont go over 3k rpm ill post pics tomorrow of how i went along mounting it, i got never ending codes. its crazy but there coming off my pr4 ecu. ill hook up the si ecu to see the codes. how do you really read the codes. i think i know how but i want to make sure. and ill look in the FAQ i think there is a post in there that shows what the codes mean.
the pr4 is prob throwing an egr valve code.
but ya read it like this
one long flash=10 so example 3 long flashes will be 30
short flashes count as one example 4 short flashes 4
so
long,long,short=21
ya understand ?
so
long,long,short=21
ya understand ?
i kinda understand.
look at this video he dont have that sensor. i have a plug off of a b18 that im sure will work.
http://www.youtube.com/watch?v=haHqFmX73cI
is there the scensor i need in the dx dizzy?
because i have the dx dizzy on the car now but its in limp mode i mean it runs good but idk. what codes will make my car go into limp mode?
i had a 89 tegg dizzy and that went bad. i changed the cap and rotor. and i had a 89 dohc Zc dizzy an that one worked for about 3months and that went bad too. i lost all spark. and i had like 6 si dizzys laying around and there all good. so i ut my dx on so i diddnt have to wire in a 6 or 7 wire si dizzy. and now the car is in limp mode. but the sensor is hooked up.
