GSR w/ LS crank help
Old Sep 4, 2008 | 11:56 AM
levee000's Avatar
Default GSR w/ LS crank help
what bearings do i need to use and what will the compression be around??
heres what i need info on
GSR block
LS crank
LS eagle rods
SRP pistons 10.7:1 in a straight LS
stock gsr girdle
B16 head not milled stock deck w/flat valves
Old Sep 4, 2008 | 12:13 PM
ruffrhyder's Avatar
Default Re: GSR w/ LS crank help (levee000)
You'll need LS rod bearings, the mains and thrust washers are the same for GSR and LS.
http://www.zealautowerks.com
Input the piston dome and comp heigth if you have them for a more accurate CR estimate.
Old Sep 4, 2008 | 12:24 PM
levee000's Avatar
Default Re: GSR w/ LS crank help (ruffrhyder)
thats the site i was looking for and i heard i can use b16 bearings that true??
Old Sep 4, 2008 | 12:41 PM
ruffrhyder's Avatar
B16 mains and thrust washers are the same as LS and GSR, but not the rod bearings.
This is the ACL Race bearing site, the ACL standard bearings are the same part numbers, just without the H or HX on the end.
http://www.aclperformance.com....s.htm
Old Sep 4, 2008 | 12:55 PM
b20vtech's Avatar
Old Sep 4, 2008 | 01:09 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by levee000 &raquo;</TD></TR><TR><TD CLASS="quote">thats the site i was looking for and i heard i can use b16 bearings that true??</TD></TR></TABLE> Yes, you can. Eagle rods do not have the oiling hole so the LS bearing is not necessary. "It is not on a LS rod either". From ACL the quality is the same, from Acura/ Honda the B16 is a better, tri-metal bearing. Just some "facts" for the day.
Old Sep 4, 2008 | 03:12 PM
levee000's Avatar
Default Re: GSR w/ LS crank help (DonF)
sweet thats what i wanted 2 kno thx
Hellahflush
Jan 28, 2015 07:20 AM
Gaspari
Sep 14, 2010 12:44 PM
dc4teg95
Apr 7, 2008 10:40 AM
nub_pwn
Feb 19, 2007 01:37 AM
crxhybrid85
Nov 30, 2004 09:48 AM
