Is there an online PDF Manual for things like changing Clock LED's?
Old Sep 4, 2008 | 07:11 AM
stormshadow1's Avatar
Default Is there an online PDF Manual for things like changing Clock LED's?
I have a 2000 Accord and would like to change Cabin Air Filter as well as Clock and Odometer LED. Any suggestions other than taking to dealer? Does 2000 Accord even have a Cabin Air Filter?
Old Sep 4, 2008 | 07:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Is there an online PDF Manual for things like changing Clock LED's? (stormshadow1)
for the cabin filter, there is a link in the FAQ...
http://syclone.motocrew.com/CG5/acfilter.htm
As for your other question... are you trying to replace a burned out bulb in the cluster?
Old Sep 4, 2008 | 07:40 AM
Default Re: Is there an online PDF Manual for things like changing Clock LED's? (TouringAccord)
Cluster? Well, my clock LED is out as well as Odometer. I just wanted to change these three things. I was told there was not a Cabin Air Filter in 2000 Accord's
Old Sep 4, 2008 | 08:11 AM
Heat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormshadow1 &raquo;</TD></TR><TR><TD CLASS="quote">...I was told there was not a Cabin Air Filter in 2000 Accord's</TD></TR></TABLE>
The person who said that was misinformed. There is definately a cabin air filter (two of them) in the 6th gen Accords.
For the clock, stop by your local dealer and buy a new bulb, will be under $2. Put some tape on the dash right under the clock (to protect the dash from scratches), then put a flat-head screwdriver under the clock / hazard button. Genty pry up, clock / hazard button slide out. Old bulb comes out after turning counter-clockwise? (haven't done it lately)
Old Sep 4, 2008 | 08:57 AM
Default Re: Is there an online PDF Manual for things like changing Clock LED's? (Heat)
Thanks, will give it a try
Old Sep 4, 2008 | 09:01 AM
spoonfedcrx's Avatar
guage cluster is pretty simple too. just take out the four? maybe screws on the cluster cover and then the remaining screws holding the cluster in and same deal as the clocklight bulb with r&r it.
Old Nov 16, 2008 | 01:32 PM
rocallaghan's Avatar
I went to the store bought a bulb. replaced it. very tiny bulb in a grey base next to the clock, still not working. I am wondering if I am doing it correctly. Is it a special bulb I need to get at the dealership?
blue01EX
Sep 4, 2010 05:10 AM
Haccord005
Dec 31, 2007 05:58 PM
J28S
Aug 16, 2005 05:21 AM
cplatt
Apr 12, 2005 03:42 PM
hk350z
Nov 6, 2004 07:45 AM
