fogs not working, what do I check??
Old Sep 4, 2008 | 06:32 AM
big_poppa492004's Avatar
Default fogs not working, what do I check??
I got my fogs on and wired by what appears to be right, I can hear the relay clicking when you push the button on and off but I noticed the switch light is not coming on and my fogs wont come on. What can I check or do next?
I did make sure all the connector points are connected good.
Old Sep 4, 2008 | 06:43 AM
ej1bmx's Avatar
Default Re: fogs not working, what do I check?? (big_poppa492004)
If they are knock offs, you might want to check the bulbs. I had some on my car, and the bulbs went bad almost right away. Almost more headache than it was worth, so ended up ripping them out and putting them in the garbage.
Old Sep 4, 2008 | 07:05 AM
Default Re: fogs not working, what do I check?? (ej1bmx)
its not the bulbs, I got a test light down where the fogs plug in (behind bumper) and im not getting any power
Old Sep 4, 2008 | 08:19 AM
DAP97SI's Avatar
Did you connected them to the battery of the car? Did you made sure the ground is correctly hooked up? Maybe need a new relay? Did you check the Fuse?
Old Sep 4, 2008 | 08:57 AM
DTA-Zombie's Avatar
ground or fuse
uf fuse is good it's your ground. get it grounded to bare metal no paint..use sandpaper or a screwdriver or something and scrape the ground area over
Old Sep 4, 2008 | 09:08 AM
IB4TL FTW's Avatar
to the OP: check my thread "Fog Lamp Install ?" I am having same problem as you.... check my thread and let me know if those are the fog lamps you purchased
Old Sep 4, 2008 | 09:12 AM
SUPAstarr's Avatar
check the clip that holds the bulb in place ive run through the wiring on my car before realizing the clip was bent a little out of shape
Old Sep 4, 2008 | 09:15 AM
IB4TL FTW's Avatar
Default Re: (SUPAstarr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPAstarr &raquo;</TD></TR><TR><TD CLASS="quote">check the clip that holds the bulb in place ive run through the wiring on my car before realizing the clip was bent a little out of shape</TD></TR></TABLE>
But then why no power to switch in inside of car either???
Old Sep 4, 2008 | 09:16 AM
MARDC5R's Avatar
on mine i had the same prob.....check the connection where the wiring hooks up to the fogs...my positive and neg were switched so i was hooking up black to red and red to black....got some needle nose took out the wire and switch it and re plugged it and it worked! good luck
Old Sep 4, 2008 | 09:22 AM
SUPAstarr's Avatar
oh didnt see that part, i got lights on my fog switch, sry
Old Sep 4, 2008 | 01:09 PM
Ok I got it working, wheeew! It was poor connection where the plug plugs into each fog light AND the solder joints were poor also where it splits to go to each fog. So what I done was re-solder at the joints and went to auto zone and got some male-female connectors and cut off the plugs on each fog AND the plugs that go to each fog and just kinda made my own connection. Now they are working fine and install was nice and clean, pretty good fitment. Hey no need and paying more than double for the Passwords when you can just get the ebay ones for a fraction of the price and do minor work to get them to work, besides when installed, look exactly the same...
Once again thanks for all the help guys, for the write-ups, links, so on and so fourth
Old Sep 5, 2008 | 01:59 PM
Default Re: (big_poppa492004)
UPDATE!!
Ok. So I got the lights working well I waited till dark to align them up, well no joke, while I was looking right at them, one just went out and wouldn't come back on, so I thought it was a blown bulb. So I took it apart and come to find out the black wire INSIDE the fog light (its what goes to the metal thing you press down to take bulb out, I think negative wire) had a bad connection so ONCE again, I cut it off and made my own connection in there. Now they work again. I think my total problem was a combination of both.
Just thought I would share this for those who are having problems they will know what problems I had so they can check theirs....hope this helps
Here ya go, car's dirty so just bare with me.
Modified by big_poppa492004 at 7:37 PM 9/5/2008
Wow let me re-size that
Modified by big_poppa492004 at 7:39 PM 9/5/2008
Modified by big_poppa492004 at 7:41 PM 9/5/2008
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
ITR.#1446
Jun 16, 2008 09:22 PM
JDM manc 10
Apr 28, 2007 06:50 PM
Chilly61383
Jun 26, 2005 11:53 AM
JDM_Type-R
Feb 13, 2004 08:36 AM
