Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Weathertech window visor question
Old Sep 4, 2008 | 05:29 AM
Nighthawk R18's Avatar
Default Weathertech window visor question
For those with the window visors, do your windows have a hard time rolling up? mine do, infact if i use the one touch window feature UP it rolls back down on the driver side. im not sure if i installed mine wrong or its supposted to happen. thanks in advance.
Old Sep 4, 2008 | 06:00 AM
IT GUY's Avatar
Default Re: Weathertech window visor question (Nighthawk R18)
I've got the Honda Visors and I've never had that issue
Old Sep 4, 2008 | 06:46 AM
SIVIC 3's Avatar
you may have installed them wrong. i would start there. are they obstructing the path of your window glass?
Old Sep 4, 2008 | 07:34 AM
Zeusone's Avatar
if i were you i would remove the visor before it brakes your window. the only time it does that is when they are new or they are not installed correctly.
Old Sep 4, 2008 | 09:39 AM
knaira112387's Avatar
it does that.. after a while the channel getrs worn from the extra mm from the visors.. then the auto up works again.
Old Sep 4, 2008 | 09:44 AM
TecHnOCal's Avatar
Default Re: (knaira112387)
^^ yup. thats what happened to mine. the auto up didnt work all the time when i first installed them. now it does. but now it seems like both sides are loose...i can hear squeeking when i go over bumps. but its not too bad
Old Sep 6, 2008 | 04:07 PM
redaf92's Avatar
I have the same widow visors and never have had that problem, i would def check to see if you put them in correctly
nfowler
Apr 11, 2017 10:08 PM
4everVtec
Nov 28, 2006 05:45 AM
RBaluca.com
Aug 20, 2006 02:08 PM
blac00si
Jul 18, 2005 04:50 PM
