B18B1 with GSR tranny vss plug doesn't match?
Old Sep 3, 2008 | 07:45 PM
Banjo the Ninja's Avatar
Default B18B1 with GSR tranny vss plug doesn't match?
Hey guys, I swapped a B18B1 into my 93 civic hatch, and it's paired with a tranny from a GSR. It all runs except the speedo doesn't work. The plug from the engine harness doesn't seem to fit into the VSS plug. Are they not compatible, or do I just need a new plug? Is there a way to bypass the plug, if I cut it off and used butt connectors? I assume that probably wouldn't work, but that's the level of desperation I've reached here with ideas to get it working.
Old Sep 3, 2008 | 10:38 PM
Tarmac Junkie's Avatar
Default Re: B18B1 with GSR tranny vss plug doesn't match? (Banjo the Ninja)
I'm not too sure on this, but if the wires are the same (same # of wires and function) but the shape of the plug is different, you could just cut and splice on the right plug.
Old Sep 4, 2008 | 05:07 AM
90SiReX's Avatar
make sure the speed sensor is pluged in with the little clip so it doesnt slip out.
Old Sep 4, 2008 | 07:43 AM
shadydb7's Avatar
Default Re: B18B1 with GSR tranny vss plug doesn't match? (Tarmac Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarmac Junkie &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too sure on this, but if the wires are the same (same # of wires and function) but the shape of the plug is different, you could just cut and splice on the right plug.</TD></TR></TABLE>
No need to cut and splice..do it the clean way and just pin it
Old Sep 4, 2008 | 05:58 PM
Default Re: B18B1 with GSR tranny vss plug doesn't match? (shadydb7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadydb7 &raquo;</TD></TR><TR><TD CLASS="quote">
No need to cut and splice..do it the clean way and just pin it</TD></TR></TABLE>
Thats a better idea. My bad.
Old Sep 4, 2008 | 10:38 PM
Steven.'s Avatar
i do believe they are all the same 94-01 with 3 pin plug, power, ground, and the information relay wire. i replaced my 96 with a 99, the bottom part of the sensor bolts up differently but the 3 pin plug is the same
scubacamper
Mar 23, 2015 03:27 PM
GsDAteg
Oct 7, 2007 12:58 PM
1sikhatch
May 7, 2006 02:02 PM
Supraznki
Oct 22, 2003 11:59 AM
