1993 Honda Civic --- Unknown Problem [yet]
Old Sep 3, 2008 | 07:35 PM
Rizzen's Avatar
Default 1993 Honda Civic --- B16 vtech --- won't rev above 3500 RPMS [neutral, gear, reverse]
I'm from Biloxi, MS. We just had this damn hurricane....
I think my ECU or SOMETHING got wet because, my car starts -coughing- and not going over 3500 RPMS... and that happens in each gear.
Now, sometimes it does that. Than I stop and shut it off... and its back to normal.
Any ideas? I got B16 motor, and chipped b18d ECU ... if that matters.
Modified by Rizzen at 3:30 PM 9/12/2008
Old Sep 4, 2008 | 11:52 AM
Rizzen's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (Rizzen)
No ideas? Suggestions?
Old Sep 4, 2008 | 12:06 PM
b20vtech's Avatar
iac perhaps?
Old Sep 4, 2008 | 10:00 PM
Rizzen's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (b20vtech)
I mean, now it runs fine... BUT i know that something is wrong? and how do i check that out?
Old Sep 4, 2008 | 10:25 PM
_smitty_'s Avatar
i remember when were im at flooded and i got stuck all i had to change was my spark plaugs because they were wet. the motor was doing the same thing that yours is doing or was doing maybe it could be your sparkplugs?
Old Sep 4, 2008 | 10:31 PM
Rizzen's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (_smitty_)
I thought about that, but the water never reached them. i was thinking it was the ECU...but never know. it runs fine now.
Old Sep 5, 2008 | 05:44 AM
Not_So_JDM's Avatar
Just an idea, and I could be wrong...but maybe it was in limp mode?
Old Sep 5, 2008 | 06:36 AM
Pothole987's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (Not_So_JDM)
may be the coil or igniter getting bad in the dizzy.
Old Sep 5, 2008 | 08:03 AM
z6hatchboy's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (Pothole987)
Im thinking maybe the ignitor going bad, you could try a friends ecu though if you know of one.
Old Sep 5, 2008 | 08:27 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (z6hatchboy)
99% ignition coil. Hurricane = huge humidity and moisture increase = shorts in the coil.
You'll probably end up replacing your entire distributor. Borrow a friend's and make sure it's the problem first to save yourself the sticker-shock
Old Sep 5, 2008 | 12:40 PM
Rizzen's Avatar
Default Re: 1993 Honda Civic --- Unknown Problem [yet] (Archidictus)
So... today it CONTINUASLY did that. Can't get above 3500 RPMS in any gear. And I noticed another thing... Black smoke coming out of the exaust?
Old Sep 5, 2008 | 01:06 PM
b20vtech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rizzen &raquo;</TD></TR><TR><TD CLASS="quote">I mean, now it runs fine... BUT i know that something is wrong? and how do i check that out?</TD></TR></TABLE>
reach ur finger inside the TB while the motor is on, block the hole passage way to the IAC sensor, if your motor doesnt stall or idle low, then ur IAC sensor is bad.
Old Sep 12, 2008 | 08:13 AM
Rizzen's Avatar
You are not speaking my language. What is TB?
Old Sep 12, 2008 | 08:25 AM
turkeyslow's Avatar
TB= Throttle Body
Remove your plastic intake tube from the intake manifold (pictured). The plastic tube connects to the Throttle Body (pictured #11) The IACV/eacv (pictured as #17)
http://www.hondaautomotivepart...+BODY
Old Sep 12, 2008 | 11:02 AM
Rizzen's Avatar
I did what you said... but I had the sensor unplugged -- car didnt idle or stall.
I know, I have to have the sensor plugged in that plastic peace. I will do that in a sec.
But here is a vid, of what it sounds like:
http://smg.photobucket.com/alb...0.flv
3000-3500 RPMS
So, if it is my distributor. ... I need to get a new one badly. But, I really dont understand whats up with it. I took the dist. box cap, and ... that does need replaces because the screw dug a whole in the cover. Perhaps cuz it was not in all they way.
Dunno ...
Modified by Rizzen at 2:17 PM 9/12/2008
Modified by Rizzen at 2:29 PM 9/12/2008
Old Sep 12, 2008 | 05:42 PM
Rizzen's Avatar
Any ideas?
Old Sep 13, 2008 | 09:21 AM
Rizzen's Avatar
Default Re: 1993 Honda Civic --- B16 vtech --- won't rev above 3500 RPMS [neutral, gear, reverse] (Rizzen)
Well, my check engine light been on since the swap. But I figured --- hey I might find something new.
21 - VTEC spool solenoid valve
10 - intake air temperature sensor
4 - crank position sensor
3 - manifold absolute pressure sensor
You guys have already told me it could be the IAT. But, WTF is 21 and 4? Or I should say...where.
Old Sep 13, 2008 | 09:25 AM
Rizzen's Avatar
And where could I get them... I looked on e-bay, the results weren't too satisfying.
carendell
Oct 24, 2013 09:13 PM
bmaya
Honda Civic (2006 - 2015)
11
Jun 30, 2009 04:02 PM
b16balfamale
11
Jan 14, 2009 07:55 AM
hondaguy74
Sep 17, 2004 11:14 AM
