Car Pulled Hard right, made bad noises, pull over then fine. Quaife LSD
Im not sure whats up and i dont want to have to pull my tranny out.
i was doing some pulls then randomly it pulled hard right felt like the wheel was loose and about to fall off. Pulled over shook the wheels as i thought it was my camber plate. drove some more all fine. Did several pulls and it did it again this time vibrating HARD and making noise like the wheel was rubbing on the dust shield all the way till i came to a stop it pulled. got back in it and it was fine. I have tried to make it do it again with no luck. Need to fig out whats wrong.
I was thinking the Quaife no clue though. no noise when driving like a bad CV or bearing. im clueless and this is really dangerous.
00 Civic Si 300whp, GSR trans, Quaife LSD, street tires
Any ideas????
Any ideas????
Drive shaft could be popping out. I would inspect the retaining ring on the driveshaft that locks it into the diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Drive shaft could be popping out. I would inspect the retaining ring on the driveshaft that locks it into the diff.</TD></TR></TABLE>
Usually that just causes the car to quit pulling. Even with a quafe. I would bet on an outer axel joint binding up. I have seen this happen before, but after it happened there was no driving. we had to change it on the side of the road.
GS-Rcivic
33
May 16, 2005 05:59 PM
