2000 accord problem with wipers
sometimes when i go to turn the wipers on with the **** instead of just pushing the lever down the wipers dont work, but it seems like if i (kick start) them with the **** turned on by pushing the lever down they will start to work... do you think the problem is in the switch or elsewhere? this only happens sometimes but i dont wanna get stuck without wipers... anyone have anything similar happen?
so i've narrowed it down to being the switch, its starting to get hard to turn it... like i asked previously, do i have to remove the entire wiper control arm? is there a plug that is inside the steering column? thanks!
I'd just swap out the full arm control system. Let me see if I can find a link real fast.
http://tasauto.com/Product/Bro...35250
BAM!
I guessed it was a sedan, but should be the same for the coupe I'd imagine.
BAM!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">I'd just swap out the full arm control system. Let me see if I can find a link real fast.
BAM!
I guessed it was a sedan, but should be the same for the coupe I'd imagine.</TD></TR></TABLE>
sounds
sounds about right
BAM!
sounds
sounds about right
BeavisB16
14
Apr 2, 2004 09:51 AM
