lowering car without coilover wrenches
Old Sep 3, 2008 | 01:43 PM
umair's Avatar
Default lowering car without coilover wrenches
i want to lower my em1 but i dont have the coilover wrenches. is there another way to adjust the height without the wrenches??
Old Sep 3, 2008 | 01:46 PM
unsungfate's Avatar
Default Re: lowering car without coilover wrenches (umair)
release the air in your tires?
uhm i think you could use some hook style wrench type things... (if you can picture what im talking about) but the actual wrenches are best.
also you may need a spring compressor or else you may not be able to turn the things to lower or raise the car because of the pressure.
Old Sep 3, 2008 | 01:52 PM
JLefevers's Avatar
Default Re: lowering car without coilover wrenches (unsungfate)
you could use a screw driver and a hammer but that may be a little harder to do with out fubar the coilovers. i would ask around town i am prety sure somebody in your town with a civic has a coilover wrench if al else fail go on ebay and buy the cheapest set of coilvers snag the wrench and turn around and sell them
Old Sep 3, 2008 | 01:53 PM
wilaivue's Avatar
just jack your car up then lossen the screw and just adjust it by hands. it's simple. no need to have that adjusting wrench.
Old Sep 3, 2008 | 02:13 PM
umair's Avatar
what screw are you talking about??
Old Sep 3, 2008 | 02:20 PM
Mark D. Surface's Avatar
Default Re: (umair)
You should be able to go to any auto parts store and get a spanner wrench.
Old Sep 3, 2008 | 02:32 PM
wilaivue's Avatar
Default Re: (umair)
some coilover have an allen head screw that holds it together but some coilover just have two of those turning thing. just losen it and adjust it by hands dude. it's completely fine.
Old Sep 3, 2008 | 02:34 PM
GYChris's Avatar
Default Re: (wilaivue)
Yeah just jack up the car and hit the ring lightly with a flathead and a hammer, wont screw up anything
Old Sep 3, 2008 | 03:50 PM
batallic's Avatar
monkey wrench
Old Sep 3, 2008 | 05:05 PM
umair's Avatar
i tried the screwdriver and hammer thing and it would not move at all. it seems like the coilovers have been on the car for a while.
Old Sep 3, 2008 | 05:23 PM
GYChris's Avatar
Default Re: (umair)
make sure you go the right way. They tighten against each other to stay "locked" at a certain height like a jam nut. make sure your not tightening them
Old Sep 3, 2008 | 09:47 PM
wilaivue's Avatar
Default Re: (umair)
WD-40=
Old Sep 3, 2008 | 11:26 PM
Radim's Avatar
PB Buster>WD-40
Try PB Buster,Discovered it when we worked on my brothers 72 Chevelle, works wonders.
Old Sep 4, 2008 | 02:22 AM
naRIPSTA's Avatar
I am my avatar
I had PB Buster, sprayed the **** out of the collars, let it run in there for a bit. Then I started hammering away on one of the hooks or what ever, it started spinning haha. I didn't hammer HARD to the point where damage shows, but I held one collar, while tapping at the other.
Old Sep 4, 2008 | 04:36 AM
4vtecn's Avatar
crc usually does the trick
Old Sep 4, 2008 | 06:19 AM
GYChris's Avatar
Default Re: (naRIPSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naRIPSTA &raquo;</TD></TR><TR><TD CLASS="quote">PB Buster
Blaster??
Old Sep 4, 2008 | 06:48 AM
DIYKITS@BB4lude's Avatar
Default Re: (GYChris)
a flat head screw driver and a hammer will work just fine
Old Sep 4, 2008 | 08:26 AM
Radim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GYChris &raquo;</TD></TR><TR><TD CLASS="quote">
Blaster??</TD></TR></TABLE>
Sorry, Yeah think so...
All i know is that it's great and it can melt a styrofoam cup.
needashell1234now
Suspension & Brakes
Jan 27, 2007 11:35 AM
CBEengineering
Suspension & Brakes
Dec 21, 2006 11:34 AM
DoctorGSR
Suspension & Brakes
17
Mar 6, 2005 06:52 PM
Chiller
Dec 17, 2004 08:33 PM
darkfx
Sep 17, 2002 11:20 AM
