Need help....
Old Sep 3, 2008 | 11:20 AM
simonEp3's Avatar
Default Need help....
Front driver side lug stud broke , I would have to remove the hub right? Then replace the bearing and all...? If so then thats not cool. Some of the other studs are gettin kinda cross threaded I guess so I will probly go ahead and replace them all if its not to hard/time consuming. Thanks in advance for the help.
Old Sep 3, 2008 | 12:21 PM
SilverDC5Driver's Avatar
Default Re: Need help.... (simonEp3)
you would not have to remove any bearings wheel studs are jus twist off but you would have to remove the rotor
Old Sep 3, 2008 | 04:49 PM
simonEp3's Avatar
Default Re: Need help.... (SilverDC5Driver)
I did have to use a hub puller to remove the hub, after the rotor came off I had to remove the big wheel hub bolt and take it off and then pound the studs out and put the new ones in, not really hard to do, but I definitely would suggest having an impact wrench handy
airikkCRX
Jan 16, 2010 04:31 PM
ewoo
Feb 24, 2009 04:23 PM
NeWsCr
Dec 13, 2006 06:43 AM
philkehn
Nov 1, 2006 09:54 AM
typeeg
Jul 20, 2004 05:21 PM
