Honda S2000 Honda S2000
How much more money is a 2002 s2k worth versus a 2001??
Old Sep 3, 2008 | 10:11 AM
ex_ricer's Avatar
Default How much more money is a 2002 s2k worth versus a 2001??
I looking for s2000's. I found a 2001 one I really like, but there's also a 2002 one also I really like. the 2002 is priced almost $2000 more. same miles and same color, same condition. I've read the official comparison of s2000 models in HT, but is the 2002 model really worth $2000 more? any feedback will be appreciated. thanks!!
Old Sep 3, 2008 | 11:43 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: How much more money is a 2002 s2k worth versus a 2001?? (ex_ricer)
It's really your call.... There are many things that make the 02 better. My fav being the option of ALL RED interior (yes I am biased) which was only available in 2002 (wht, blk, silver) and early 03 (silver only)
Changes in 2002:
As a design theme, Honda added "metallic accents" to the car inside and out.
Interior:
• Stereo gained digital bass/treble/fade/bal controls
• Stereo now has a silver faceplate from black
• Stereo now 30W/ch, up from 20W/ch
• Door speakers changed from paper cones to blue plastic
• Two additional speakers added in the doors - tweeters
• The shift **** now aluminum and wrapped leather
• Shift **** weighted - now heavier
• Black interior trim around the IP changed to dark gray (metallic look) plastic from black plastic
• Metal rings added to the interior door panel pulls
• The tonneu cover changed. There is only 1 clip on the each side to push in from underneath. Reportedly it is easier to attach and doesn't appear to 'flap' up like previous design
• Heat and A/C fan are more powerful. The 2nd and 3rd fan speeds are noticeably more effective
• The cup holder cover and trash hole behind it are textured plastic as opposed to the same untextured earlier ones
• The dead-pedal is now metal/rubber and matches the other pedals
• A leather console cover replaces the carpet console cover
• The soft-top now has a glass window and rear-defroster in place of the original plastic window
• The buttons for the defroster and cruse-control on switches are a different shape
• The new window defrost button is the cruise control on the right side of the steering wheel
• The tach indicator line is now white and the scale connected by a solid white arc line
• A second post has been added to the carpeted floor mats to secure them
• Very small storage pockets were added to the doors
• Metal placard on door sills slightly revised
Exterior:
• The shade of wheels are a slightly darker silver with a little more metallic-flake
• Chrome rings added to the tail-lights
• There is a small subtle change in the trunk lid shape at the rear, near the trunk brake light. Reportedly this was to meet the Federal safety standard measurements
• The outside Honda badges are larger
• Paint color changes were made. In the US, Sebring Silver replaced Silverstone Metallic (the newer is a brighter silver). Suzuka Blue Metallic was added
Chassis:
• The front sway bar was slightly reduced in size to provide a more forgiving ride.
Engine:
• ECU reprogrammed - 02-03 S2000s typically make ~10 more whp than 00-01s and run a bit less rich up top
• Oil banjo bolts upgraded
• Transmission "improved" (stated by Honda) for shifting
Old Sep 3, 2008 | 02:50 PM
mingus's Avatar
I had an '01 and now I have a '02. The biggest difference is the glass rear window. The folded plastic window sucked. There's leather around the gearshift and a dead pedal. There are tweeters. They suck, but it's better than nothing.
I think the '02 is a more refined car. If you're going to buy a '01, make sure it has a hardtop.
Old Sep 3, 2008 | 09:54 PM
ricepicker's Avatar
Default Re: How much more money is a 2002 s2k worth versus a 2001?? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">It's really your call.... There are many things that make the 02 better. My fav being the option of ALL RED interior (yes I am biased) which was only available in 2002 (wht, blk, silver) and early 03 (silver only) </TD></TR></TABLE>
wow. for some reason I thought GPW had All Red in 03 when I was searching for my car. Must have been searching for 02-03 instead of just 03.
Old Sep 4, 2008 | 03:43 AM
Black S2K's Avatar
i really dont see the upside to getting a 02 besides the glass window in the top. If the plastic window and top is fine on the 01 then save ur money for some mods.
Old Sep 4, 2008 | 04:01 AM
i my honda
Global Mod
Default Re: How much more money is a 2002 s2k worth versus a 2001?? (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">
wow. for some reason I thought GPW had All Red in 03 when I was searching for my car. Must have been searching for 02-03 instead of just 03.</TD></TR></TABLE>
I read that info somewhere on s2ki. So I am not 100% sure on that... I do know I have never personally even SEEN an 03 with all red interior.
Old Sep 4, 2008 | 04:40 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
if u can get the guy with the 02 to come down a little, then def get the 02... rear glass window FTW!!!
Old Sep 4, 2008 | 11:34 AM
Import_Fan's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">i really dont see the upside to getting a 02 besides the glass window in the top. If the plastic window and top is fine on the 01 then save ur money for some mods.</TD></TR></TABLE>
The glass window makes a big, big difference.
Old Sep 4, 2008 | 11:54 AM
S2KILLA's Avatar
Default Re: (Import_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan &raquo;</TD></TR><TR><TD CLASS="quote">
The glass window makes a big, big difference.</TD></TR></TABLE>
and its a newer car
Old Sep 4, 2008 | 11:57 AM
Chris.'s Avatar
Honda-Tech Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan &raquo;</TD></TR><TR><TD CLASS="quote">The glass window makes a big, big difference.</TD></TR></TABLE>
you mean the fact that its not going to be hazy? other than that, there is nothing. if the top tears... it doesnt matter if its a plastic or glass window...its going to need to be replaced
Old Sep 4, 2008 | 09:16 PM
bky's Avatar
bky
Default Re: (Chris.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. &raquo;</TD></TR><TR><TD CLASS="quote">
you mean the fact that its not going to be hazy? other than that, there is nothing. if the top tears... it doesnt matter if its a plastic or glass window...its going to need to be replaced</TD></TR></TABLE>
The plastic window can crack in cold weather too, especially if old. That's what happened to mine, with a small crack that started from a falling tree-branch. From there, the whole thing split when I put the top down on a cold morning.
Keep in mind that if the top on an 00-01 needs to be replaced, you can upgrade to glass for about $100-200 more.
Old Sep 4, 2008 | 09:39 PM
HondaKyle's Avatar
Default Re: (bky)
I was putting my top down after the car was out side over night and the top was still cold so the plastic window cracked in half
Old Sep 4, 2008 | 11:17 PM
riceball777's Avatar
2002 is the only year with all red interior ftw. + glass rear window. thouse are the 2 month inportant changes i think
Old Sep 5, 2008 | 04:48 AM
Chris.'s Avatar
Default Re: (bky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bky &raquo;</TD></TR><TR><TD CLASS="quote">That's what happened to mine, with a small crack that started from a falling tree-branch. From there, the whole thing split when I put the top down on a cold morning.</TD></TR></TABLE>
well image a shattered window if that tree fell on it... or imagine if the tree never fell on your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">I was putting my top down after the car was out side over night and the top was still cold so the plastic window cracked in half </TD></TR></TABLE>
:knock on wood: mine hasnt cracked, but my car is garage kept and driven maybe once a week
Old Sep 9, 2008 | 05:02 PM
Black S2K's Avatar
um what? no it does not i actually perfer the plastic over glass as as its not hazy. Glass window is smaller compared to the plastick. Plus i have driven my old freinds 03 countless times and i didnt notice a big big difference.
Thats why you dont put that **** down when its cold. Plus you can get a robbins top with glass window for around 500 bills on ebay with the retrofit kit so it cant fit the 00-01 if the top tears or rips.
I have a small tear in my top i was thinking about replacing it but [freak] it i barely drive topdown anyways just gonna get a ht and thrwo out the softop.
Old Sep 10, 2008 | 02:41 PM
al4t1gbundy's Avatar
Granted the owner may have neglected it .... but let me tell you. After seeing this 01 S2k in my campus parking lot a couple of times with the plastic window shot to hell ... I must say I would definately not want to own one.
Damn thing looks like caca and a half!
Old Sep 10, 2008 | 02:50 PM
Black S2K's Avatar
^ lol
gsr squirrel
Honda S2000
Feb 10, 2005 06:36 PM
2camsaam
Honda S2000
19
Feb 23, 2003 05:16 PM
Muckman
Honda S2000
78
Jul 7, 2002 02:26 PM
sshus
Honda S2000
Jan 26, 2002 07:50 AM
