Z6 Trans/ECU code???
Old Sep 3, 2008 | 10:06 AM
Deadlock281's Avatar
Default Z6 Trans/ECU code???
On Friday I'm going to pickup a Z6 Engine, Trans, and ECU (ONLY 79k miles!). I know where the engine code is. What I need to know is where are the codes for the trans and ecu (if there are any)? I just want to make sure I'm getting the right things. IF POSSIBLE, PICS WOULD BE PREFERRED. Thanks guys.
Old Sep 3, 2008 | 10:41 AM
thegoudster's Avatar
Default Re: Z6 Trans/ECU code??? (Deadlock281)
the ecu is a p28. there's a sticker on the ecu with some numbers and p28 is in the middle. see image.
Old Sep 3, 2008 | 11:00 AM
Sweet, thanks man.
Old Sep 3, 2008 | 03:51 PM
BUMP for the Transmission code and its location.
Old Sep 3, 2008 | 04:47 PM
batallic's Avatar
IIRC, s20 b000 sumthin like that
Old Sep 4, 2008 | 04:58 AM
thanks
Old Sep 4, 2008 | 07:23 AM
DTA-Zombie's Avatar
block code will be right on the front blank spot - the transmission should be a b0000 (that is a 92-95 ex/si tranny)
decklyn18
Mar 13, 2007 04:50 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
