Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
squeeking after skunk2 rear camber kit instal
Old Sep 3, 2008 | 09:26 AM
Greg50Lt's Avatar
Default squeeking after skunk2 rear camber kit instal
Ove the labor day weekend i installed my skunk 2 rear camber kit and went and had an alignment. Everything is in spec and now all of a sudden when i go over big bumps or speed bumps the rear seems to be getting noisy. anyone having this problem or know what i could do to get rid of it?
Thanks
Old Sep 3, 2008 | 10:21 AM
TypeRBoy's Avatar
Default Re: squeeking after skunk2 rear camber kit instal (Greg50Lt)
Did you use ALL the lube they gave you with the kit?? You replaced a rubber part with a polyurethane part. Poly squeaks like a bitch if you don't use an absurd amount of lubrication. I found this out first hand on my SRT-4 sway bar install. I used the supplied lube, but did not thoroughly lubricate the bushings. It squeaked very badly until I took off the bars and re-lubricated them. Do not change any of the adjustments the alignment shop made, just remove them and LUBE.
Old Sep 3, 2008 | 06:50 PM
Greg50Lt's Avatar
thanks. i lubed the one end and not the other because the the bolt holds it into place and that dosnt do any movement. i guess ill just take it off again and relube it.
Old Sep 4, 2008 | 07:36 AM
Zeusone's Avatar
mine didnt come with lube and they never squeek
Old Sep 4, 2008 | 08:24 AM
IT GUY's Avatar
Default Re: (Zeusone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeusone &raquo;</TD></TR><TR><TD CLASS="quote">mine didnt come with lube and they never squeek</TD></TR></TABLE>
Old Sep 4, 2008 | 09:50 AM
Greg50Lt's Avatar
mine didnt either but i put a lil bit up grease on it before i installed it. ima see how things are after i install the skunk2 pro-s let my buddy whoes doing the alignment look at it and let me kno.
Type_R_Nammer
Suspension & Brakes
16
Oct 29, 2009 03:04 PM
deadazleep
Dec 4, 2006 05:01 PM
djtony5
Dec 30, 2003 05:04 PM
Flux
Jun 9, 2003 05:10 PM
HYREV2NR
May 23, 2003 09:11 AM
