Classic Hondas All Pre-1988 Hondas.
Accord-Hot weather-Intermitent rough idle and drive
Old Sep 3, 2008 | 09:04 AM
mharris251's Avatar
Default Accord-Hot weather-Intermitent rough idle and drive
I have a 1989 Accord LXi , automatic w/ air. I am experiencing sudden and intermittent rough idle and rough acceleration. This only happens in the spring and summer on warm or hot days after the car has been parked outside. IE in a parking lot.
Initially the car starts and runs fine and then within a few blocks in begins to shake and idle rough at the first or second stop. I must pull over and restart the car. This may happed several times. After that the car runs fine
Occasionally the check engine light will come on and a reliable mechanic advises me the code indicates “throttle body sensor”. However the sensor tests ok. This mechanic advised it may even be a bad wire somewhere related the throttle body sensor
I recently had a problem with fueling the car that could be related. I could barley get it to take the fuel without constant splash back. I noticed a lot of vapor pressure upon removal of the gas cap. The cap is not vented and it’s the correct cap. I’m wondering if this is part of the problem like some sort of vapor release mechanism is not working under the hood. Our recent smog check indicates the catalytic converter is down to its last few years ( it did pass smog/California car)
What could be wrong? Only happens in the summer, especially when its really hot. Never happens in the winter.
Thanks
Mharris251
96hatchBoy
Sep 18, 2012 03:45 AM
snider
Feb 1, 2012 02:58 PM
jaybur_racing
Jun 11, 2007 07:24 PM
Vp Special K
Apr 4, 2003 09:14 PM
