dx & si dizzy (same part number)
I can't find a used si dizzy so I looked to see how much a new one would cost.
I compared the two and they are the same part number.
Is it a myth that you have to swap these to do the mpfi conversion?
I just never understood what would be different in the two.
They are both nonvtec obd0.
Opinions?
Opinions?
From: I told you to wait in the truck in Texas, United States
The "Si" or MPFI distributor has an extra sensor
through which the ECU determines which fuel injector to fire or "pulse"..
Since the DX uses a throttle body,all cylinders are fed together
instead of fueling each cylinder individually so the extra sensor is omitted.
the 2 distributors do not have the same part number.
OBD0 DX/LX dizzy part number......................TD-01U
OBD0 Si/EX dizzy part number.......................TD-02U....and TD-18U
the people working the computer at the parts counter generally aren't the brightest, so entering correct data seems to be a challenge. Either that or their parts database doesn't contain the information..
I just checked Advanced Auto Parts online store for kicks, and found this:
3117401 is the td-01u dpfi 7 wire distributor part number $228.29 & $100 core
3117402 is the td-18u mpfi 9 wire distributor part number $154.54 & $75 core
no idea why the si/ex distributor is almost $100 cheaper, when it is a more complex part.. but whatever..
i work at kragens have where ever you go look closely at the description within the description it tells you or quite simply have them pull it from the shelf and then just look at the plugs 1 square 1 round means its a DX, if there are 2 round plugs then its si
thedudefromjerz
Feb 15, 2008 09:48 AM
beatthisspeed69
13
May 5, 2007 01:34 PM
slpnz6
May 10, 2006 03:18 PM
Big Bang
14
Aug 22, 2003 06:18 AM
