Honda S2000 Honda S2000
What brand oil you running?
Old Sep 3, 2008 | 06:45 AM
egvtec's Avatar
Default What brand oil you running?
Ive been searching this out to see what people like to use in the high revving F series engines.
Have no clue being such a noob to the AP1
Its been all B series for me
Old Sep 3, 2008 | 06:57 AM
chimmike's Avatar
Pennzoil platinum full syn. Excellent reviews on BITOG.
Old Sep 3, 2008 | 07:22 AM
bky's Avatar
bky
Mobil 1
Old Sep 3, 2008 | 07:23 AM
White Smoke's Avatar
i my honda
Global Mod
Default Comparison oil tests of 10w30 for S2000
This info is from 2003:
Originally Posted by Road Rage "Comparison oil tests of 10w30 for S2000"
These are the most comprehensive and recent ones I could find. They date to March 2003 and May 2003. I will post the numbers, add a comment or two, and answer any questions you may care to pose. These tests were commissioned by Amsoil, but since they use standardized ASTM protocols, they could easily be verified, and any deception challenged. Based on my experiences with the products from all these companies, and the results of similar but less comprehensive tests posted elsewhere, these do not look doctored or suspect. But as I did not oversee them, I cannot and will not be accountable for any discrepancies, real or imagined. This was a lot of work to type, and I strived to get them right.
1. All the oils were 10w30 viscosity
2. The oils tested were:
Amsoil (syn)
Castrol GTX Drive Hard (mineral)
Valvoline Synpower (syn)
Mobil Drive Clean (min) - isn't this the rebadged Honda oil?
Pennzoil Purebase (min)
Quaker State (Syn)
Quaker State Peak Perf (min)
Castrol Syntec (syn)
Valvoline (min)
Pennzoil Synthetic (syn)
Mobil1 SuperSyn (syn)
The following ASTM tests were run:
Thin-film Oxygen Uptake ( D-4742)
High Temp/High Shear ( D-4683)
NOACK Volatility ( D-5900)
Pout Point (D-97)
Total Base Number (D-2896)
Cold Cranking Simulator D-5293)
4-Ball Wear (D-4172)
Test 1: Thin Film Oxygen Uptake:
Measures the oxidation stability of an oil.
The induction time (break point) in minutes is measured. The test uses standard amounts of fuel dilution, soluble metals, and water to offer a real-world applicability.
Results for this test(all units in minutes):
Amsoil: >500 (no break)
Mobil1: 397
Pennzoil Purebase: 242
Castrol Syntec: 221
Valvoline: 219
Vavoline SynPower: 211
Mobil Drive Clean: 209
Quaker State Peak Performance: 192
Pennzoil Synthetic: 159
Quaker State Synthetic: 159
Castrol GTX Drive Hard: 132
Test 2: High Temperature/High Shear (HT/HS)
Measures a lube's performance under severe heat and shear (mechanical stress) as would be found in the journal bearings under heavy load. The units displayed are viscosity based, using the centipose unit (cP). The minimum spec for a 30w is 2.9 cP.
Results for this test (all units in cP):
Amsoil: 3.51
Quaker State Peak Performance: 3.37
Castrol GTX Drive Hard: 3.35
Vavoline SynPower: 3.30
Mobil1: 3.30
Valvoline: 3.30
Mobil Drive Clean: 3.28
Pennzoil Purebase: 3.16
Quaker State Synthetic: 3.15
Pennzoil Synthetic: 3.14
Castrol Syntec: 3.13
Test 3: NOACK Volatility.
Measures the evaporative loss of lubricants in high temperature conditions. The higher the number, the thicker the lubricant will become. API SL and GF-3 specs allow for a 15% evaporation limit. In this test, obviously, lower is better. Syns almost always have an advantage due to their monomolecularity.
Results for this test (% weight loss):
Amsoil: 4.86
Vavoline SynPower: 7.03
Castrol Syntec: 7.77
Quaker State Synthetic: 7.80
Pennzoil Synthetic: 8.15
Mobil1: 8.92
Castrol GTX Drive Hard: 8.93
Quaker State Peak Performance: 10.63
Mobil Drive Clean: 10.83
Pennzoil Purebase: 10.93
Valvoline: 12.18
Test 4: Pour Point
This test reveals the lowest temperature at which a lubricant will flow when cooled under test conditions. The lower, the better the product will perform in getting from the oil pan to the upper oil galleys, and in providing oil pressure quickly. Synoils generally are the best, because they are free of wax crystals, but today's mineral oils are better refined to remove wax impurities, and use advanced pour point depressant additives to help offset the synoils' intrinsically better properties.
Results for this test (all units in degrees Centigrade):
Amsoil: -48
Mobil1: -46
Vavoline SynPower: -46
Castrol Syntec: -43
Pennzoil Synthetic: -40
Quaker State Synthetic: -40
Pennzoil Purebase: -37
Valvoline: -37
Mobil Drive Clean: -37
Castrol GTX Drive Hard: -37
Quaker State Peak Performance: -34
Test 5: Total Base Number (TBN)
TBN displays the lubricant's reserve alkalinity, and is, of course, the opposite of TAN (total acid number). A high TBN will help resist the formation of acids from sulfur and other sources. It is also a good indicator of reserve resistance to oxidation. The higher the number, the superior ability to suspend contaminants and the greater the ability to provide long-drain intervals
Results for this test (all units in mg KOH/g):
Amsoil: 12.34
Vavoline SynPower: 11.38
Castrol Syntec: 10.39
Pennzoil Synthetic: 9.73
Mobil1: 8.57
Valvoline: 7.88
Quaker State Synthetic: 7.82
Castrol GTX Drive Hard: 7.74
Mobil Drive Clean: 7.71
Quaker State Peak Performance: 7.55
Pennzoil Purebase: 7.40
RR's comments: I was very impressed with all the oils, as the mineral oils have significantly improved, consistent with previous comments about how mineral oils are closing in, and that the GF-3 spec has resulted in very good performing products. Mobil1's showing is the best i have seen for that product, which usually was in the 5-6 range previously. It certainly also supports my previous comments that the 3K oil change "necessity" is out of place with current technology. Like an enema for a dead man, while it may not help to do a 3K change, it wouldn't hurt I guess.
Test 6: Cold Crank Sumulator
This one determines the apparent viscosity of the oils at low temperatures and high shear rates, simulating the dreaded cold start. It has direct applicability to engine cranking, the lower the number the better in terms of stress on the battery, starter, etc. A 10w is tested at -25degF and must show a vis <7000 cP to pass.
Results for this test (all units cP at -25degC):
Pennzoil Synthetic: 3538
Amsoil: 3590
Mobil1: 3967
Quaker State Synthetic: 4142
Vavoline SynPower: 4541
Quaker State Peak Performance: 4620
Castrol Syntec: 4783
Castrol GTX Drive Hard: 5804
Pennzoil Purebase: 5936
Mobil Drive Clean: 6448
Valvoline: 6458
RR Comments: If you live and drive your car in very cold climates, the advantage of the synoils is obvious. Keep in mind that the NOACK performance figures here as well, as this tests hows the performance of fresh oil - after a few thousand miles, the oils with higher volatility will likely have thickened, unless there has been high dilution from fuel, such as can occur if excessive startup idling warmups are employed.
Test 7: Four Ball Wear
This one is a good indicator of the wear protection of a lubricant, although in the real-world it is should be factored in with the TBN of the oil. Three metal ***** are clamped together, and a rotating 4th one is pressed against them in sliding contact. A scar is produced, since at some point the film strength (resistance to being squeezed out) of the oil will be exceeded. The scar is then measured, and the smaller the average wear scar, the better. This test is affected by both the base stock of the oil, and its additive package.
Results for this test (all units in inches):
Amsoil: 0.40
Castrol Syntec: 0.45
Vavoline SynPower: 0.55
Quaker State Synthetic: 0.55
Mobil Drive Clean: 0.55
Pennzoil Synthetic: 0.60
Mobil1: 0.60
Valvoline: 0.60
Castrol GTX Drive Hard: 0.60
Quaker State Peak Performance: 0.60
Pennzoil Purebase: 0.65
RR Comments: Amsoil and Castrol Syntec are the clear frontrunners, indicating excellent chemistry and use of anti-wear additives. Once again, the high performance of the mineral oils against the 2nd tier synoils is notable, although one cannot dismiss the superiroity of the synoils across the board.
Final comments:
I think that except for one of the lubes, there was a wide discrepancy of performance for the others - one might be good here, not so good there. As in life, consistency of performance is what sets apart the great from the good.
As Voltaire said, "The best is the enemy of the good". Perfectly good performance can be found in any of these products, and a thinking owner would factor his/her driving styles, operating conditions (environmental), maintenance schedule (intervals between changes), cost constraints, buy vs lease, and expected length of ownership into making a choice.
Now, what about the other top synoils? Well, they were not tested here, but certainly the industry giants were. Based on tests I have run or seen from sources I trust in the industry, Red Line, NEO, Motul, and others would likely score in the top quartile of these tests. The tests anmd UOA's I have seen for Royal Purple have never shown it to be other than mid-tier, competitive with the synoil or GIII mineral oils from the major companies.
Hope this is useful to you - I found it fascinating to watch the goo go head to head.
Happy Motoring!!
Old Sep 3, 2008 | 07:31 AM
i my honda
Global Mod
Default Re: What brand oil you running? (egvtec)
Lot's of good information here> The OIL JOURNALS
Old Sep 3, 2008 | 08:11 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: What brand oil you running? (White Smoke)
tt seems like castrol syntec is 'better' than mobil1... ill have to try that next time i change my oil
Old Sep 3, 2008 | 08:14 AM
i my honda
Global Mod
Default Re: What brand oil you running? (Chris.)
Amsoil FTW
Old Sep 3, 2008 | 08:49 AM
SuzukaBlueAP2's Avatar
Redline
Old Sep 3, 2008 | 09:14 AM
chimmike's Avatar
m1's 'superiority' has been a myth the past 5 years or so. Everyone seems to think it's the best, when there are better syns available cheaper.
Old Sep 3, 2008 | 11:32 AM
HondaKyle's Avatar
Default Re: (chimmike)
That purple stuff
egvtec's Avatar
So full syn is the way to go? BTW that info was excellent to know
Old Sep 3, 2008 | 11:38 AM
HondaKyle's Avatar
Default Re: (egvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">So full syn is the way to go? BTW that info was excellent to know </TD></TR></TABLE> YEAH! It also says that in the owners manual...
Old Sep 3, 2008 | 01:50 PM
chimmike's Avatar
Default Re: (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">That purple stuff </TD></TR></TABLE>
read the last paragraph of that whole article.
RP has never been a fantastic oil. The price sure isn't fantastic.
Old Sep 3, 2008 | 01:55 PM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
RP has never been a fantastic oil. The price sure isn't fantastic.</TD></TR></TABLE> Ive been using it for a year almost. I notice my car started running better with the first time I put it in, plus I dont pay full price...
Old Sep 3, 2008 | 02:26 PM
mingus's Avatar
Default Re: Comparison oil tests of 10w30 for S2000 (White Smoke)
Good info.
I've noticed that price wasn't considered. I use Synthetic Mobil1, 5qts for $25 from Wal-mart. Not to be a cheap-***, but I buy in bulk.
Old Sep 3, 2008 | 04:20 PM
Oleg's Avatar
Amsoil all the way!
Old Sep 3, 2008 | 06:59 PM
iam7head's Avatar
valvoline and valvoline only
Old Sep 4, 2008 | 04:45 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: What brand oil you running? (iam7head)
SEARCH!!!
Old Sep 7, 2008 | 12:52 AM
FoShoei's Avatar
Default Re: What brand oil you running? (S2KILLA)
Mobil 1 !!!!!!!!!!!
Old Sep 7, 2008 | 07:56 PM
Hugo.'s Avatar
Default Re: What brand oil you running? (FoShoei)
whatever costs the most is obviously the best.
but i think im goin to have to make a change to amsoil here....
Old Sep 8, 2008 | 05:58 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
Default Re: What brand oil you running? (Hugo.)
I use mobil 1 but I may switch to amsoil. It's just that I can't find a store that sells it
Old Sep 8, 2008 | 06:05 AM
egvtec's Avatar
Default Re: What brand oil you running? (jdm-ray)
Ive seen alot of people using Mobil 1
Old Sep 8, 2008 | 06:42 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-ray &raquo;</TD></TR><TR><TD CLASS="quote">I use mobil 1 but I may switch to amsoil. It's just that I can't find a store that sells it</TD></TR></TABLE>
That's a problem for allot of people unfortunately. You have to find a shop that carry's it.
Old Sep 8, 2008 | 07:54 AM
egvtec's Avatar
Mobil one oil center 5 miles from my house
Old Sep 8, 2008 | 08:03 AM
i my honda
Global Mod
Yeah, too bad Mobil one sucks in high revving motors.
