Leaky Windshield
Old Sep 3, 2008 | 06:07 AM
Jaysen777's Avatar
Default Leaky Windshield
I've got a 90 civic SI HB,
just did a B16A swap a little while ago,
Everything on the car is mint except for that just recently I discovered the roof corners where the windshield meets has rusted from the inside out leaving small holes.
Now that i'm refinishing the entire body for a new spray coat, does anyone know a good and permanent solution or fix on sealing a roof as such?
Old Sep 3, 2008 | 09:45 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: Leaky Windshield (Jaysen777)
Sand down rust.
Fill in with epoxy putty.
Then use Permatex windshield sealer special stuff.
Old Sep 3, 2008 | 10:52 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Leaky Windshield (phoenix_iii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenix_iii &raquo;</TD></TR><TR><TD CLASS="quote">Sand down rust.
Then use Permatex windshield sealer special stuff.</TD></TR></TABLE>
I wouldn't exactly call putty and epoxy permanent.
You should grind all the rust out and tack weld small holes / shape and weld new metal into bigger pieces.
Old Sep 3, 2008 | 04:28 PM
beige89civic's Avatar
* B A N N E D *
Default Re: Leaky Windshield (wiZCo)
I think he mean't bondo
Old Sep 3, 2008 | 05:36 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Leaky Windshield (beige89civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic &raquo;</TD></TR><TR><TD CLASS="quote">I think he mean't bondo</TD></TR></TABLE>
Even so, that's not permanent either.
Old Sep 4, 2008 | 08:37 AM
Jaysen777's Avatar
Thanx for the input,
Definetely will go with tack welding strips of sheet metal over those sections, will more likely last longer than just a regular autobody filler and spray over job.
Especialy if I have to drive another brutal winter.
Old Sep 5, 2008 | 05:05 PM
* B A N N E D *
Default Re: (Jaysen777)
That's the way too go.
msinsky14
Paint and Body
Aug 29, 2007 11:50 AM
rusted_eyes
Honda Motorcycles
May 21, 2005 10:49 AM
GreenMachineRex
Jun 23, 2004 06:15 AM
gribbs
Apr 27, 2004 11:14 AM
gary201147
May 13, 2003 10:14 AM
