89"crx disc brake fit on a 91' crx hI?
Old Sep 3, 2008 | 04:38 AM
rocketman987's Avatar
Default 89"crx disc brake fit on a 91' crx hI?
like it says will they fit or do i need extra parts? thanks for your help.
Old Sep 3, 2008 | 05:51 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: 89"crx disc brake fit on a 91' crx hI? (rocketman987)
Did you mean HF? I isn't even close to F.
Did you mean SI? S isn't really close to H, either...
Old Sep 3, 2008 | 06:04 AM
kojack_0's Avatar
the only difference is how the caliper bolts to the bracket. 88-89 bolts are much smaller than 90-91. but the 17mm bolt for the whole caliper assembly with the bracket should bolt up fine. meaning you should use 88-89 bracket for 88-89 caliper and 90-91 bracket for 90-91 caliper.
88-89 CRX
90-91 CRX
in terms of the brake disk itself, they should be interchangable between years of crxs.
Old Sep 3, 2008 | 06:26 AM
thanks for the help and btw si the last post helped alot thanks
Old Sep 3, 2008 | 07:16 AM
kojack_0's Avatar
no problem.
hondapimp125
Jun 13, 2009 10:25 PM
endlesswinterco
Suspension & Brakes
May 15, 2008 07:13 AM
higgunscrx
Jun 21, 2007 12:53 PM
HondaBurger
Welding / Fabrication
Mar 5, 2007 05:45 AM
Jonathan_ED3
22
Aug 25, 2005 03:26 PM
