1993 Integra DB1 - How to remove climate control?
The light behind the climate control sliders is going on and off. There's a loose connection somewhere. How should I go about fixing this problem?
Thanks in advance, all help is appreciated
First off, check the obvious: make sure that the connectors are firmly plugged in and have no loose wires. The step after that is to bust out the multimeter and check continuity before the unit, before the bulb, after the bulb and after the unit to try and verify exactly where the problem is. If no luck, climate control units are usually cheap.
EDIT: I have no idea how to remove one from a second gen Teg though.
Modified by Kendall at 9:07 PM 9/4/2008
zertoir
May 1, 2004 06:41 PM
