Tach going crazy (erratic) on 95 V6 Accord
Old Jul 24, 2002 | 04:06 PM
dlbshonda's Avatar
Default Tach going crazy (erratic) on 95 V6 Accord
Need help on a 95 V6 Accord. After about 10 minutes running, tach goes up and down and won't stay stable. After engine is off and cooled down, works again until warmed up. Any suggestions appreciated.
Old Jul 24, 2002 | 04:36 PM
Chiovnidca's Avatar
Default Re: Tach going crazy (erratic) on 95 V6 Accord (dlbshonda)
Is it just your tach acting erratic or is your engine reving up and down?
Old Jul 24, 2002 | 05:10 PM
YeuEmMaiMai's Avatar
sounds like you need to either replace a coil, cap or rotor
Old Jul 24, 2002 | 06:01 PM
dlbshonda's Avatar
Default Re: Tach going crazy (Chiovnidca)
Engine runs steady while tach jumps around. While driving with tach jumping, it does has a miss every once in a while.
Old Jul 24, 2002 | 06:27 PM
Chiovnidca's Avatar
Default Re: Tach going crazy (dlbshonda)
It could be a bad coil.
Old Jul 24, 2002 | 07:21 PM
Martaigne's Avatar
Or an electrical short, I have the same symtom right before I get a massive short that draws all power from the alternator and battery.
Old Jul 31, 2002 | 05:17 PM
dlbshonda's Avatar
Thanks for the bad coil tip. Checked coil after it warmed up and the resistance was all over the ohm meter (blue wire tach terminal and coil end. Replaced coil and tach is steady.
mrbighead
Feb 21, 2016 08:32 PM
GLOCKIT
Sep 4, 2010 06:16 AM
hueyjock
May 29, 2007 09:09 AM
mikeb33
Jun 13, 2005 05:35 PM
starchland
Jul 9, 2004 04:57 AM
