Parting out 89 crx many many extras
Old Sep 2, 2008 | 05:08 PM
crxsleeper210's Avatar
Default Parting out 89 crx many many extras
Ok First off i am parting out my crx because i have run out of money to spend and i have debts that i need to pay so its my loss your gain......
The entire car will be parted out first come first serve....
i am willing to ship any part that may be needed but buyer will pay for shipping at their own expense.....
I will post pics of almost everything but if something is not pictured or listed i most likely have it i just forgot to list it. i can send you a picture of any specific item via email just send me an IM and i'll get back to you asap....
And so the list begins
B16a motor OBD0 motor from jdm Integra XSi DA8. Has approx. 45 -48 thousand miles on it. I purchased itwith 78 thousnd kilomoters on it from the shop where i bought it and i only put approx. 3000 miles on it so you do the kilometers to miles conversion. It was tuned up by me twice.....Once every 1500 miles( i like my motors to be fresh) give or take 100. Only red line 10w-30 oil was used and HAMP oil filters. Ngk iridium plugs and wires were only used on this motor. Transmission was filled with genuine honda MT fluid but is now drained. Never had any problems whatsoever. I ran a 9.4 on the 1/8 mile track at irwindale completely stock in my crx with no suspension mods and horrible tires. Motor is completely stock and in very good condition it pulls real hard especially in a crx. The ecu is not for sale because that is being held for a friend. It was running on the stock jdm pr3 ecu ot of an xsi integra da8. The only mod done to the engive is I painted the valve cover Spoon yellow. I think it came out very clean i even sanded down the raised lettering to give it a stock appearance.
..............Just the head(includes new oem valve cover gasket set, intake manifold and throttle body)is........................................... ....... $450 NO LONGER FOR SALE
..........................Head and Block(block has brand new oil pan)..$ 600 NO LONGER FOR SALE
S1 cable transmission perfect condition with no grinds in perfect condition (non LSD).............................................. ..............$450
Innovative alluminum mounts for B series swap w/ cable transmission into any EF (red bushings)......................................... ....................$200
90 integra axels good condition no rips or signs of wear.....$60
90 crx si door panels good condition....................$100
stock 89 crx front sway bar with new oem bushings $40
Custom made shift linkage( 90 integra linkage cut and welded) for B series swap into any EF.....$100
B&M racing shifter with the alluminum housing that the shifter sits in for any Honda/Acura...................................$75 SOLD SOLD SOLD
Aluminum radiator good condition(stock replacement)..........$50 SOLD SOLD SOLD
94 integra LS Mesh wheels pretty good condition i'd say a 7.5 or 8 out of 10 with brand new tires ($50 a piece) already balanced from tucker tire(forgot the brand of tires)........$400
91 crx si oem wheels decent condition with tires but i highly recommend changing the tires asap.....$100 SOLD SOLD SOLD
92-95 civic EG armrest black and in perfect condition(used it in my crx)....$50
Rear bumper for 88-89 crx (needs paint).....$40
Brand new OEM 88-89 crx HF front bumper support(very lightweight)......$75
Used Crx HF Rear bumper support for 88-89 crx(lightweight as well)........$40
Genuine JDM honda access window visors for crx . These are brand new in the box ......$200 firm
Walbro 255 high flow fuel pump used for 6 months........$50 SOLD SOLD SOLD
brand new oem honda shift boot for crx.....$20 SOLD SOLD SOLD
Function 7 Rear lower control arms.........$150SOLD SOLD SOLD
Genuine Honda front lip for 88-89 crx like new condition only one small scratch on the bottom which you can't even see...........................$75 SOLD SOLD SOLD
90 crx si black dash complete except for cluster ....$75
89 crx dx blue dash complete except center console (comes with MT cluster)..$50
91 crx si seats in very good condition only small rip on driverside....$100 SOLD SOLD SOLD
91 crx taillights with oem "CRX vtec" decal........ $100 SOLD SOLD SOLD
91 crx si rear disc conversion with new brembo rotors and new wagner pads, also comes with new oem Brake Prop. Valve from a 91 si and new oem brake lines as well as brand new wagner master cylinder for a crx si (pads rotors and brake lines have 1-2 miles on them)......$250 for everything SOLD SOLD SOLD
Brand new sill in the packaging 88-89 crx side moldings (will fit 90-91 crx also)...$150
Brand new in the box door sills both driver and passenger....$20 each SOLD SOLD SOLD
Brand new in the box rear triangle pieces( and yes the one on the left has the oem "honda"decal the other side is blank)......$20 a piece SOLD SOLD SOLD
Gates racing timing belt for b16 brand new....$40
Ground control coilovers only 1-2 miles on them (like new)...$300
Ground control top hats for any Honda/Acura.........$200 SOLD SOLD SOLD
Koni yellow shocks like new only 1-2 miles on them (front shocks were stripped of paint by me for cosmetic reasons).....$450
Skunk2 front Upper control arms like new ......$200 SOLD SOLD SOLD
Complete crx si rear interior (color is black)..let me know what you want and ill give you a price
EM Racing C-pillar bar for Crx.........$75 SOLD SOLD SOLD
Real Sparco Front strut brace for 88-91 civic/crx....$100 (i paid $250 new) SOLD SOLD SOLD
Real VIS CF hood with jdm hump in the middle (looks like oem jdm hood but only fits us spec front ends).....$350 SOLD SOLD SOLD
Headlights with brand new 90-91 headlight brackets....$60
Brand new Genuine Honda front bumper for 88-89 crx........$100
Stock fenders with Genuine crx sidemarkers........$100 SOLD SOLD SOLD
Rear sony xplod 4 way speakers with the metal bracket ( i will sell just the bracket if interested).....$60 SOLD SOLD SOLD
Both doors have no dents and are also for sale with glass....$45 a piece ( that is a steal)
Rear tailgate with glass and no wiper motor (from a 90 hf)....$100
Rear quarter glass....$30 per side
Front windshield............ $75
Mudguards like new condition...........$60 for all four SOLD SOLD SOLD
Front knuckles painted cast iron grey with brand new brembo rotors, brand new ball joints and brand new oem hubs(the hubs cost 100 a piece from the dealer) as well as brand new oem brake dust shields and brand new wheel bearings. This set up cost me over 400........$350 for both
Front lower control arms with brand new oem bushings already pressed in......$40 SOLD SOLD SOLD
If there is anything not listed that you might want dont hesitate to ask and ill let you know what i have and what i don't have.....Now for the pictures
Modified by crxsleeper210 at 5:44 PM 9/2/2008
Modified by crxsleeper210 at 5:46 PM 9/2/2008
Modified by crxsleeper210 at 7:00 PM 9/2/2008
Modified by crxsleeper210 at 5:53 PM 9/3/2008
Modified by crxsleeper210 at 6:22 PM 9/3/2008
Modified by crxsleeper210 at 5:16 PM 9/4/2008
Modified by crxsleeper210 at 2:33 AM 9/8/2008
Old Sep 2, 2008 | 05:52 PM
bump
Old Sep 2, 2008 | 06:34 PM
Wazup's Avatar
Default Re: Parting out 89 crx many many extras (crxsleeper210)
wow, its like a CRX play land.
bump for a local
any idea on how much you let the whole b16 swap go for?
Old Sep 2, 2008 | 07:06 PM
Default Re: Parting out 89 crx many many extras (Wazup)
id let the motor , tranny, shiftlinkage, mounts, and ecu (even tho im not supossed to sell it) for 1350...can not be negotiated because i paid 1300 just for the motor tranny ecu so this is a deal
Old Sep 2, 2008 | 10:50 PM
bump...parts are going faster than i expected
Old Sep 2, 2008 | 11:24 PM
CW-ITR's Avatar
Old Sep 3, 2008 | 01:23 AM
Default Re: Parting out 89 crx many many extras (CW-ITR)
bump before bed.......its funny i have had offers for everything pretty much except the motor which i thought would be gone first...its coo though...
Old Sep 3, 2008 | 06:33 AM
dbailey's Avatar
Still have the tranny? My 90 Civic LX sedan and grinding.
Old Sep 3, 2008 | 09:08 AM
redh22alude's Avatar
pm'd
Old Sep 3, 2008 | 04:07 PM
Default Re: Parting out 89 crx many many extras (dbailey)
yea i have they tranny but this is for a b series moror...it wont work on your stock lx single cam motor
Old Sep 3, 2008 | 04:49 PM
UPDATE
Mudguards and front lip SOLD SOLD SOLD to blueboorex89_razors
Old Sep 3, 2008 | 05:00 PM
UPDATE
FENDERS HAVE BEEN SOLD SOLD SOLD
Old Sep 3, 2008 | 05:20 PM
LOV2XLR8 94Z28's Avatar
Sent Pm about motor, and a couple other goodies.
Old Sep 3, 2008 | 05:22 PM
Default Re: (LOV2XLR8 94Z28)
k
Old Sep 3, 2008 | 05:33 PM
EFSedan#6's Avatar
Bump for looking.
Old Sep 3, 2008 | 05:39 PM
i also forgot to post i have an innovative mounts traction bar (the new one not the replacement crossmember) for sale for 275 plus shipping....has 2 miles on it never been launched on.......
Old Sep 3, 2008 | 06:04 PM
mgs1098's Avatar
Watching this.. The EM Bar and front control arms are mine..
Alan
Old Sep 3, 2008 | 06:07 PM
Default Re: (mgs1098)
Holding front control arms and em bar for mgs1098 pending payment by tomorrow
Old Sep 4, 2008 | 12:25 PM
mgs1098's Avatar
Payment sent Bro..
Alan
Old Sep 4, 2008 | 04:14 PM
control arms and em bar and window trim sold to MGS
more pics of other stuff will be up in an hour or so
Old Sep 4, 2008 | 06:10 PM
Vinceg99's Avatar
Default Re: (crxsleeper210)
bump for you.
Old Sep 4, 2008 | 06:31 PM
Default Re: (Vinceg99)
MORE PICTURES OF STUFF FOR SALE
HERE ARE THE PRICES FOR THESE PARTS
NOTHING IS NEGOTIABLE UNLESS STATED SO DONT ASK OR YOU WILL BE IGNORED
SEATS............................................. ...........................$100
WINDOW VISORS............................................ ............$200 SOLD SOLD SOLD
BRAND NEW OEM HONDA SIDE SKIRTS.........................$180 SOLD SOLD SOLD
BRAND NEW OEM HONDA CRX (88-89)MOLDINGS...........$150
BRAND NEW OEM BOTTOM DOOR PLASTIC PROTECTORS........$200
BRAND NEW OEM SHIFT BOOT (88-91 CIVIC/CRX)..........$20 SOLD SOLD SOLD
USED CUSTOM CRX FLOORMATS...............................$30 SOLD SOLD SOLD
EG ARMREST GREAT CONDITION (WILL FIT CRX).................................$50
90 CRX SI DASH WITH MOONROOF SWITCH (NO CLUSTER).................$100 THIS IS NEGOTIABLE
90 CRX SI CARGO BOX............................................... $30
90 CRX SI CARGO DIVIDER WITH CARPET.....................$40
90 CRX SI CARGO COVER (NOT PICTURED BUT IT EXCELLENT CONDITION NO RIPS OR SIGNS OF WEAR).........................................$75 FIRM
94 INTEGRA LS RIMS WITH NEW TIRES(2 MILES ON THE TIRES).......$400
BRAND NEW OEM HONDA DOOR SASHS/SILLS(THE ONES ON THE B PILLAR)........................................... .........................$20 EACH
MOMO STEERING WHEEL HUB FOR 88-91 CIVIC/CRX..........$40
NRG QUICK RELEASE HUB (RED)..................................$40
B&M RACING SHORT SHIFTER...................................$50
SKUNK2 TITANIUM SHIFT ***(THIS IS THE HEAVY ONE)........$30
INNOVATIVE TRACTION BAR NEVER DRIVEN ON...................$275 THIS IS NEGOTIABLE
COMPLETE REAR PLASTIC INTERIOR FROM 90 CRX SI(NOT INCLUDING CARGO INTERIOR OR BOX).............................................$ 200 FIRM
B16A OBDO VIRGIN PR3 MT ECU (NOT PICTURED).............$100 THIS IS NEGOTIABLE
BRAND NEW OEM HONDA LOWER FENDER PLASTIC PROTECTORS....$20 EACH SOLD SOLD SOLD
IF YOU HAVE ANY QUESTIONS PM ME....
THANKS FOR LOOKING....GOOD LUCK
Modified by crxsleeper210 at 8:01 PM 9/4/2008
Modified by crxsleeper210 at 1:22 AM 9/5/2008
Old Sep 5, 2008 | 02:20 PM
LOTS OF UPDATES.............
FUNCTION 7 LCAS.......................SOLD SOLD SOLD
SKUNK2 ARMS........SOLD SOLD SOLD
WALBRO FUEL PUMP..............SOLD SOLD SOLD
NEW OEM SHIFTBOOT...............SOLD SOLD SOLD
ONE PAIR OF GROUND CONTROL TOP HATS .................SOLD SOLD SOLD
SPARCO FRONT TOWER BRACE......SOLD SOLD SOLD
TRACTION BAR & RADIATOR........ON HOLD FOR THE MOMENT UNTIL TOMORROW FOR LDO
PASSENGER SIDE DOOR SASH/SILL...........SOLD SOLD SOLD
REAR DISK CONVERSION..............SOLD SOLD SOLD
NEW OEM SIDE SKIRTS...........SOLD SOLD SOLD
NEW OEM TRIANGLES.........SOLD SOLD SOLD
FLOORMATS...................SOLD SOLD SOLD
NEW OEM LOWER FENDER GARNISHES..................SOLD SOLD SOLD
DRIVER SIDE DOOR SASH/SILL..........SOLD SOLD SOLD
SI SEATS......WILL BE SOLD TOMORROW
WINDOW VISORS .....................SOLD SOLD SOLD
Old Sep 5, 2008 | 04:32 PM
TheSauceSpot's Avatar
pm'd
Old Sep 6, 2008 | 08:56 AM
Default Re: (HOTSAUCE01)
UPDATE
PASSENGER AND DRIVER SIDE DOOR SASHS........................SOLD SOLD SOLD
CRX SI SEATS............................................. ...........SOLD SOLD SOLD
RADIATOR........................................SO LD SOLD SOLD
INNOVATIVE TRACTION BAR...............................SOLD SOLD SOLD
VIS CARBON FIBER HOOD....................................SOLD SOLD SOLD
GROUND CONTROL TOP HATS.........................SOLD SOLD SOLD
MOMO HUB AND NRG QUICK RELEASE................SOLD SOLD SOLD
STILL FOR SALE
INTEGRA LS RIMS ON NEW TIRES..............400
FULL CRX SI REAR INTERIOR GOOD/VERY GOOD CONDITION MAKE OFFERS
CRX SI DOOR PANELS....................................$100
90 CRX SI DASH COMPLETE.....................................$100 THIS IS NEGOTIABLE
89 CRX DX BLLUE DASH WITH THE SPEEDOMETER CLUSTER................$50
JDM S1 B16A CABLE TRANSMISSION MINT CONDITION (NON LSD).......$500 OBO
INNOVATIVE MOUNTS (B SERIES CABLE INTO EF)...........................$200
GROUND CONTROL COILOVERS AND KONI YELLOW SHOCKS (LIKE NEW)......$850 FIRM
DOORS...........$50 A PIECE
MY PASSENGER DOOR IS STOCK 89 AND DRIVER DOOR IS 91 CRX DOOR.
BRAND NEW CRX HF FRONT BUMPER SUPPORT (88-89)...........$70
USED HF REAR BUMPER SUPPORT (88-89)...............................$20
KNUCKLE AND HUB ASSEMBLIES.........................$350 FIRM
ALPINE MP3 HEAD UNIT GREAT CONDITION..............$50
SONY XPLOD 4-WAY REAR SPEAKERS........................$40
REAR METAL SPEAKER BRACKETS..........................$30
B&M RACING SHORT SHIFTER ASSEMBLY..............$50
SKUNK2 TITANIUM SHIFT ****........................$30
STOCK FRONT CROSSMEMBER WITH CUT-OUT TO FIT 4-1 HEADER FOR A CRX WITH A B SERIES SWAP................................$50
THERE IS MORE TOO IM JUST FORGETTING
