Transmission Fluids
Yes. GM Synchromesh Fluid FM is good stuff. I used it in my 1991 Civic I had and after 100K, no grinds at all. Now, as far as a newer car, I have used RedLine MTL in my 2005 EP3 and have had no grinds whatsoever and I have driven hard and tracked the car a couple of times. The RedLine allows the gears to shift like butter. If you were to take a brand new Honda with Honda MTF, drive it for a while, then drain and fill with RedLine, you would notice a definite difference of feel in the gears. Also, you could add in Honda MTF with Lucas oil additive. It works well to stop grinding in transmissions.
x2 i had a 3rd gear grind and my 5th gear would get stuck whe i would try to take it out but i used Redline and now my gears don't even grind or get stuck it goes in like new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EduardoDC5 »</TD></TR><TR><TD CLASS="quote"> now my gears don't even grind or get stuck it goes in like new
...that's what SHE said!
</TD></TR></TABLE>...that's what SHE said!
they dont sell gm synchromesh anymore i believe.
honda mtf is just like gm synchromesh. pick some of that stuff up.
changed the tranny fluid in my ep and it felt like a brand new car again after 60K.
honda mtf
honda mtf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy »</TD></TR><TR><TD CLASS="quote">they dont sell gm synchromesh anymore i believe.
It's under a new name now. I believe Pennzoil makes it but it says equivalent to GM synchromesh right on the bottle.
I use Honda MTF. Was only like $12 at the Acura dealer (2 qts).
DOHCRX
20
Jun 26, 2003 11:35 AM
