obd-0 to 0bd-1
Old Sep 2, 2008 | 10:12 AM
crxH4's Avatar
Default obd-0 to 0bd-1
Hey guys,
I need to convert to OBD1. I am running a stock D16A and i know i have to change to a 4 wire 02 sensor but i dont know what type of distributor i need. I have read so many different suggestions but they all contradict each other. I is hust a obd0 D16A non-vtec head. Which obd1 dizzy would fit. The reason i am going to go to obd1 is to run a Hondata.
Any help?
Old Sep 2, 2008 | 10:33 AM
crx_si-r's Avatar
Default Re: obd-0 to 0bd-1 (crxH4)
the distributor that you need is a TD-41U or TD-42U.
TD-41U found on DX, LX civics from 92-95
TD-42U found on EX, Si civics from 92-95
it all depends on what your set up is going to be. if your stayin non vtec you can use a TD-41U but it might not bolt up to your current motor. i know when i did a mini me i had to modify the ears to bolt up to my old D16A6 bottom and D16Z6 head.
Old Sep 2, 2008 | 10:51 AM
crxH4's Avatar
Default Re: obd-0 to 0bd-1 (crx_si-r)
thanks for the info!
i am going to keep the engine stock with the D16A head.
anyone got one of those distributors laying around or know where i can get one.
Old Sep 3, 2008 | 07:38 PM
crxH4's Avatar
another questions,
The Td-41U says it is for the 1.5L . Is it ok to run on the 1.6L. or what about the TD42U that is for Vtec engines. Is that ok to have even if im not running vtec
Old Sep 4, 2008 | 10:23 AM
crxH4's Avatar
any takers
Old Sep 4, 2008 | 01:41 PM
hammergunner's Avatar
if the motor has a distro already just rewire it for obd0, this is assuming you have a si or hf car
the other two wires black and blue, wire right up the the new distro black and blue wires
crxdonwon
Feb 19, 2009 05:53 AM
94blkHB
Jul 20, 2007 07:20 PM
richboi
11
Apr 17, 2006 04:36 PM
crxsirvtec
Oct 27, 2003 09:13 AM
ShiroX
May 6, 2003 02:11 AM
