DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP
Old Sep 2, 2008 | 09:27 AM
93hondaboy's Avatar
Default DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP
MY BROTHER HAS A JDM TYPE-R MOTOR. HAS ISSUES WITH VTEC WORKING THATS HIS ISSUE. BUT THE MAIN PROBLEM IS ITS HAVIN G DRIVABILTY ISSUES IN NEUTRAL IT REVS FREELY BUT WHEN PLACE UNDER LOAD IT BREAKS UP AND MISSES. I HAVE CHECKED EVRYTHING ON THAT CAR TEN TIMES OVER. BUT I THINK IS FAR MORE DEADLY THE PROBLEM WERE HAVING, HAS ANYONE EVER HAD AN PROBLEMS WITH ELECTRICAL IN THE CAR. IM THINKING THE INTERIOR HARNESS MIGHT BE FAULTY BUT I DON TKNOW CAN SOMEONE PLEASE HELP
Old Sep 2, 2008 | 04:31 PM
JDMGTI's Avatar
Default Re: DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP (93hondaboy)
ok. could be a lot of things. gonna need more info. its a little vague.
so. try all your grounds. ALL of them. pull wiring around the engine bay and see if there is a loose connection. thats what got me when I thought it was the car harness.. same symptoms, NO Check Engine Light.. had a friend wiggly some of the engine harness around and figured out that an injector ground ungrounded itself from the injector clip. just one, and for no apparent reason, it just did it whenever throwing off everyone I knew.
Old Sep 3, 2008 | 06:43 AM
srmofo's Avatar
Default Re: DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP (JDMGTI)
you havent checked everything 10 times or you would of found it ten times, spray some water on the plug wires and see if they are arching, dont forget to check down the holes under the covers
Old Sep 4, 2008 | 09:13 AM
BLACKLIST138's Avatar
Default Re: DESPARATE DOWN TO THE POINTOF NO RETURN!!!!!!!!! READ UP (srmofo)
id edit your sig till you figure it out..
I mean would you even buy ice cream off someone asking you how to make it?
drift2004
May 12, 2011 06:40 PM
IS3Fifty
Oct 19, 2003 05:49 AM
jazz215
May 5, 2003 09:15 PM
DjDrift
Mar 2, 2003 07:05 PM
