My EG....drag car or street car? which way should i go?
So ive been working on this car for about 6 months and our track finaly opened up. And up to this point its been just a fast street car. But friday it went to the dyno and put down 357hp at 12psi and did an 11.5@127. Do i lean it more towards a drag car or keep it a clean street car? need your guys opinions. I didnt expect the car to go this fast and now im really hooked. But i dont wanna lose the street ability. But i really want a solid 10 second street car...is that asking too much?
Engine:
'95 JDM B18B
'95 USDM B16A3 Del Sol head
Golden Eagle head studs
Skunk 2 Pro intake manifold
Motorola 2.5 bar map sensor
MSD 8.5mm plug wires
Full Throttle Fuel pressure regulator
BDL fuel rail
NOS Fuel pressure gauge
'98 GSR cams
CTR N1 pulley
Precision 1000cc injectors
Walbro 255 intank
P75 ecu (I think) converted to VTEC, street tuned on Crome Pro with antilag in place and building 10psi.
Turbo:
Holset HX35W
Treadstone FMIC
2.5" Charge pipes
2.5" Open downpipe
XS Power Wastegate
XS Power BOV
SSAC twisted manifold
VooDoo Boost controller (12-13psi)
Transmission:
'95 JDM B16A non-LSD
'98 Type-R flywheel
XTD Stage 3 clutch with 8K
Suspension:
G.A.B. coilovers (height and dampening)
unknown control arms
Brakes:
Cross drilled and slotted front rotors
EBC pads
GSR rear discs
GSR Brake booster and master (not installed yet)
Braided lines all around
Interior:
2000 Type R seats
Si gauge cluster
Auto-Meter Sport Comp wideband
Auto-Meter Sport Comp Boost Gauge
Auto-Meter Sport Comp Pyrometer
Auto-Meter Oil Pressure
Bolt in 4 Point roll cage
Relocated Battery
Grant steering wheel
OEM 98 Prelude CD player
JDM Center Console
Outside:
Honda OEM 15" wheels with Falken Tires that are brand new (Street)
MT 22x8x15 slicks (track)
Type R front lip
RS sideskirts
Carbon Fiber hood
In my bedroom I have a freshly sleeved benson block, CP pistons and eagle rods. I wanna shooty for 600 hp.
So what do you guys think?
A vid of the pass.
Engine:
'95 JDM B18B
BDL fuel rail
'98 GSR cams
CTR N1 pulley
Walbro 255 intank
Turbo:
Holset HX35W
Treadstone FMIC
2.5" Charge pipes
2.5" Open downpipe
XS Power Wastegate
XS Power BOV
Transmission:
'98 Type-R flywheel
Suspension:
Brakes:
EBC pads
GSR rear discs
Interior:
2000 Type R seats
Si gauge cluster
Relocated Battery
JDM Center Console
Outside:
Type R front lip
RS sideskirts
Carbon Fiber hood
A vid of the pass.
it's up to you if you have another car lined up to drive around while the hatch becomes a track queen.
How's the no A/C and no power steering working out?
Only reason why I would say go for all track is so you can ride comfy in something else but if you're content with it on the street, why not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCLA.lion »</TD></TR><TR><TD CLASS="quote">it's up to you if you have another car lined up to drive around while the hatch becomes a track queen.
Ive got my daily 93 accord with all the good daily stuff. I guess i have to keep it somewhat streetable to drive to the track since i cant afford a truck and trailer.
I say turn it into a street/strip car. I've seen a couple guys daily drive their low 10 sec SFWD cars on the street, and the weekends they tear it up on the track. I hope your planning to upgrade that manifold/wastegate right?
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBrian »</TD></TR><TR><TD CLASS="quote">I say turn it into a street/strip car. I've seen a couple guys daily drive their low 10 sec SFWD cars on the street, and the weekends they tear it up on the track. I hope your planning to upgrade that manifold/wastegate right?
Good Luck</TD></TR></TABLE>
the manifold is holding up good and making good power. But yes, the wastegate is being upgraded to a Tial 44mm gate.
lol what a funny question.
1. do you have another car if you decide to dedicate this one to the drag strip?
2. do you have lots of money?
3. who cares anyways.
makes good power and is pretty damn quick. but imo a long way away from a drag car. my buddy was daily driving a 2.0 sleeved motor with a 42r and twin disk etc etc.... Id say keep it as a street car. but only 1 opinion matters and thats yours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK »</TD></TR><TR><TD CLASS="quote">id take the crank pulley off and put a stock one back on it...</TD></TR></TABLE>
nah, theres nothing wrong with it. i know the "stories" about how some guys buddies girlfriends brother was using it and it shattered the oil pump. But i have not talked to a person directly who has said that the pulley has for sure caused a problem. Its was in my teg for over a year, and now 7 months in the hatch with no problems at all.
Nice, I have the same steering wheel in my DA. And I hate it
Anyway, if you want my opinion, I'd say make it a track car. But, I prefer those strange tracks where the road curves. If you want to go fast in a straight line (and it seems like you really like doing so), then make it a drag car. A few more mods and you'll probably hit 10's, hopefully you don't give up so much that it becomes undriveable on the street--like you mentioned, you still want to drive it to/from the track.
Just an update:
An AEBS closed deck bottom end with Ross pistons, pauter rods, Z10 girdle, all ARP hardware.
Skunk 2 Pro 1 cams with skunk cam gears
AFI top mount manifold, divided housing with twin 44 gates.
Still left to buy, Edelbrock victor X, full blown dual walbro, Borg Warner S372.
