high compression ls (ctr pistons)
Old Sep 1, 2008 | 07:31 PM
singlesecondEF's Avatar
Default high compression ls (ctr pistons)
Well im building a motor and i wanted to get some advice on what i should and shouldnt do. and anything to help me out. im building a high compression b18a1, ctr pistons, ls rods, ls head, hasting rings, i want to build it with out any problems with the ls rods being to weak or spinning a berring, anything like that. let me know what you guys think. thanks
Old Sep 1, 2008 | 08:01 PM
slofu's Avatar
Default Re: high compression ls (singlesecondEF)
principles of proper engine-building discussed here many times in the past will carry over for you. search for threads discussing non-vtec builds, lsvtecs, etc. while they may not provide an exact blueprint for you, they'll teach you lots. also, get a Helm manual and find a good machinist.
Old Sep 1, 2008 | 08:20 PM
projectTeG's Avatar
first things first on the ls rod, upgrade rod bolts and get them refreshed.
Old Sep 1, 2008 | 09:52 PM
jpnolan's Avatar
I'm trying to do a similar build but with aftermarket rods but can't seem to get any info out there on an all motor ls. good luck let me know if you find anything good.
Old Sep 3, 2008 | 06:35 AM
Default Re: (jpnolan)
thanks guys, i know about building a motor its just i have been hearing bad things about this build, deff about the ls rods being weak and the rod bolts,
Old Sep 3, 2008 | 02:13 PM
slofu's Avatar
Default Re: (singlesecondEF)
ls rods are fine, as long as you upgrade the bolts.
No offense, but before I'd bother spending the $ for PCT pistons, etc., I'd spend the $ for a B16 or gsr head w/stock cams/valvetrain, mill it, and throw it on a stock LS shortblock (w/upgraded rod bolts). If you're considering aftermarket ls cams/valvetrain in addition to the PCT slugs, lsvtec is cheaper, likely to make more power, and has more potential.
revhard215
Nov 11, 2006 06:42 AM
Freek
Apr 11, 2006 04:16 PM
hinds90
Feb 14, 2005 09:50 PM
redrex
12
Jul 2, 2004 06:26 AM
MugenB16A2
14
Nov 14, 2003 09:13 AM
