del sol fog lights
2 questions about the sol fog lights
1. does anyone know where to get the edm lower fog lights for the 96+ front ends? or what diameter lights will fit similar to the edm versions.
2. if you were to convert from a 96 front end to a 93 style, will the oem aux lights mount ok on the 96 frame? or is the 96 frame missing a bar where the aux lights mount to? is there any work around for this?
wanting to convert to a 93 style, but if its too much work to modify for the oem aux, then i'll go for the edm lower fog lights.
thanks.
thanks.
i think u can buy the ek fogs from password jdm for the 96-98 front end. u have to get the circle ones and make a bracket for them 2 stay on.
i tried using the ek squares and they didnt work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*EG2 »</TD></TR><TR><TD CLASS="quote">those 96/97 optional fogs are discontinued in both the clear and yellow</TD></TR></TABLE>
he knows his stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphisraines26 »</TD></TR><TR><TD CLASS="quote">you can swap your 96 front for the 93 easily. the frame is the same with mounting points for the middle aux lights.</TD></TR></TABLE>
and so does he
he knows his stuff
and so does he
eclaire
Mar 6, 2009 11:06 AM
coffman08
Aug 31, 2007 04:39 AM
