Clutch slipping need comformation
Okay so today I took the civic out and the rpm was staying higher than usual when I shift, then it got worst. I had to baby the **** out of it just to get it to move. When I gave it gas it wouldnt go anywhere, but the rpm was going up. The pressure plate is still very firm so Im thinking its the clutch disc. Just need conformation before I attempt anything. thanks
That definately sounds like a slipping clutch, get a new clutch kit, replace the clutch disc, pressure plate, pilot bearing and throwout bearing. Either have the flywheel resurfaced or replaced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch »</TD></TR><TR><TD CLASS="quote">pressure plate is still almost new, you think I can get by with just the disc</TD></TR></TABLE>
Personally i'd just replace all of it, its really not gonna cost you that much more. You might get away with it, really depends on if it got warped from being heated up when the clutch was slipping.
eg customs
Nov 7, 2008 09:28 AM
JDiMageDC2
Apr 10, 2008 07:39 AM
bboylito
Apr 10, 2005 05:47 PM
SOHC_Brian
May 23, 2004 05:15 PM
