Weird brake issues... I need help
Old Sep 1, 2008 | 11:17 AM
pythoner's Avatar
Default Weird brake issues... I need help
I had an issue with my brakes, after I stopped my car running or not with the brakes off the next time I hit them (not the first time) there is next to nothing. I replaced a caliper that looked bad and a master cyclinder because it was leaking, then blead the brake and now I have even less brake power than before.
thanks for the help.
Old Sep 1, 2008 | 01:20 PM
pythoner's Avatar
help
Old Sep 1, 2008 | 01:27 PM
itsmejto's Avatar
you HAVE to bench bleed the master, you block both ports, pump till it won't pump any more, then connect the lines before it all leaks out again.
Old Sep 1, 2008 | 04:03 PM
pythoner's Avatar
I did, I am not a complete novice here...
but I was told that my vacuum booster is probly toast, but I am going to bleed the hell out of the brakes tomorrow and see what happens
hteg12
Jul 18, 2013 05:13 PM
pythoner
Suspension & Brakes
Sep 3, 2008 04:01 PM
EG2Driver
Apr 22, 2008 07:17 PM
justforkicks
Sep 16, 2006 06:18 AM
