water coming from the blower
on my 93 accord, lately when i turn on the A/C water starts to drip from between the blower and the evaporater. i can see its coming from the blower because i took off the the holding brackets of the evap. and u can see the water draining from the blower side. what can it b
Condensation. The condensation/water is normal, for it to leak into your car is not. There should be a condensation/water drain tube going from the bottom of the case out through the firewall. Check to make sure it's not clogged.
