FS: Peakboost, Boomslang, OBD0 - OBD1, Rear Disk, B16, GSR, O2 Sensor
All prices are OBO, but please be reasonable. Buyer pays for all shipping. Everything sold AS IS. Please BUMP if you view.
Semi Built B16 Block $1277
Block has about 570 miles
Block:
-Since first run i have been using Valvoline 5w30, honda coolant, and honda oil filters and has had several oil changes
-I wiped the cylinders down with oil and have kept the block covered since the head was removed(thats why you can see oil in the cylinders)
-Just run for break in with NO boost
-Built by Performance Engine and Machine in Middelton, WI
-Cleaned, Resurfaced, Rotating assembly balanced, Bearings coated, Pistons thermal coated
-9:1 Mahle Pistons
-Eagle Rods
-Race Engineering Block Guard
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-New Bearings and Thrust Washers
-ARP Head Studs
-All timing covers
-All new gaskets and seals
-Will come with stock crank pulley, not the Fluidamper
-New Thermostate
-Doesnt come with a knock sensor
Modified by civiwhip at 10:01 PM 10/15/2008
Block:
-9:1 Mahle Pistons
-Eagle Rods
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-ARP Head Studs
-All timing covers
-New Thermostate
