front wheel bearing for 2003 honda accord
i have a humming noise coming from my right front. it sounds like my wheel bearing is bad. i was wondering if anybody knows how to change the wheel bearing on a 2003 honda accord.
Hi there,
I have a 2004 Accord sedan (4 cylinder). My right rear wheel bearing went at around 40,000. Unfortunately I do not know how to change it. But I took mine to the dealer where they fixed it at no charge under the "good faith" gesture. I think it would have been about $300.00. They said it should not have gone out with so few miles on the car.
Depending on how many miles you have, you might want to give it a try??
Good Luck.
Good Luck.
Remove the steering knuckle, press out the hub, remove the retaining clip and press out the wheel bearing.
After you replace a couple, it's an easy job, but it's not really for your average do-it-yourselfer.
Railroader
Feb 12, 2017 11:30 AM
bassichonda96
Jun 5, 2005 01:29 AM
